Can I retrofit an older rear diff to my '80
Canadian Events Coordinator
Can I put a stronger rear diff like the older Vettes in my '80? Will I have to change much?
Premium Supporting Vendor
Re: Can I retrofit an older rear diff to my '80 (AGVI)
Yes you can. The housing will bolt up to your aluminum wing. Your going to have to change your strut rods b/c they are angled different. You also have to change half shafts. The 63-79 half shafts are 13 7/8" long from center cap to center cap and the 80-82 half shafts are 13 1/2" from center cap to center cap. You will also need to buy spindle flanges(2) b/c yours are a different style. We have a Hi-Performance kit that we sell and when we get and 80-82 vette in we alway put the cast iron (63-79) rears in them.
Your probably looking at about $1500 - $2000. But it all depends on what you get. If you find a rear at a sway meet or something that will probably save you some $ as long as you can buy one for under $300. How much HP do you have? You may want to go w/stronger than stock half shafts also. I would say it all depends on how much HP you have and what you plan on doing w/the car.
Re: Can I retrofit an older rear diff to my '80 (Van Steel)
I was under the impression '80 rear ends were quite good, now half shafts can snap but I thought the punkin itself was good ?
