Vent behind passenger kick panel
Old Nov 3, 2003 | 11:22 PM
gb9743's Avatar
gb9743
Default Vent behind passenger kick panel
I removed the kick panel on the passenger side to expose the vent mechanism. Much to my surprise, I found what appeared to be half of the insulation from behind the dash. It appears that the mice have been hard at work.
After cleaning the mess up and dis-assembling the vent mechanism, I found that the rubber (?) seal around the oval shaped closing disc was destroyed. Upon closer inspection, it looks like the oval shaped disc is comprised of two pieces of metal that are riveted together with a rubber gasket imbetween the two pieces. I haven't had any luck finding this part listed in a catalog anywhere. Has anyone replaced this part and where did you find a replacement? :banghead:
Old Nov 4, 2003 | 06:21 AM
GaryS's Avatar
GaryS
Default Re: Vent behind passenger kick panel (gb9743)
This part is sold by Dr. Rebuild. It is a very easy fix. Drill out the rivets, remove the old rubber diaphram, replace, re-rivet.
Gary
Old Nov 4, 2003 | 06:40 AM
Nomad78SA's Avatar
Nomad78SA
Default Re: Vent behind passenger kick panel (GaryS)
I bought one through corvette america.
It is simple to do as Gary said.
Neil in Tenn
Old Nov 4, 2003 | 07:34 AM
Ybnormal's Avatar
Ybnormal
ZIP also has the seal kit, I think about $10, and you are correct the seal is sandwiched between two plates. The kit comes with the seal and rivets for the rebuild.
YBNormal...drive a vette
Old Nov 4, 2003 | 08:46 AM
gb9743's Avatar
gb9743
Default Re: Vent behind passenger kick panel (Ybnormal)
Thank you all. :)
Old Nov 4, 2003 | 01:52 PM
HDFLH67's Avatar
HDFLH67
Mine don't open! Which control are they supposed to be connected to? Part of the heater controls or is there a seperate operator somewhere?
Thanks!
Old Nov 4, 2003 | 11:31 PM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
I fixed mine for free by making a new seal from a piece of rubber roofing material sandwiched between the 2 plates as original. The original was felt, I think the rubber will hold up just fine, works great.
Edit: now that I'm thinking about it, the original was not felt, it was a sponge rubber material of some sort.
[Modified by Big Fish, 10:33 PM 11/4/2003]
To Vent behind passenger kick panel
