oh no! not another suspension engineering thread! :O
Here's my trans tunnel, hard to see but it's much wider than stock, these are old pics, the tunnel is now even wider than in these pics. Lots of hammerforming (carefull, that steel likes to shear)
After all is done I''m going to make a cover plate out of fiberglass and seal and pop rivet it in place (or i may install nut plates, simpeler for when removal is needed) It looks a bit rough in the pic.
TwinTurbo that doesn't look like your usual work? You are as neat or neater then I am.
[Modified by norvalwilhelm, 4:31 PM 11/5/2003]
[Modified by norvalwilhelm, 4:33 PM 11/5/2003]
Those a-holes never paid a dime for the reparis, all I got away with was not paying for the (minor) repair they did :(
I made it as pretty as I could:
The dents are real obvious here, pic taken before any work to the floor was done:
Here's the mess they left, the hole is caused by the u joint hammering all the way through.
It now is a lotcleaner than in that pic, it was taken just after hacking out that section of metal
[Modified by Twin_Turbo, 5:00 PM 11/5/2003]
I also can not stand bend pieces and I can imagine your discust when they dented your floor.
I do all work at home. The last time I had an alignment in 69 I was told my 428 had a miss at 7000 when out test driving to check the alignment. Never again has anyone worked on my muscle cars, never.
I finished one coil over tonight, finished welded, ginding, test fitting and it is now being painted. I will give it a couple of coats then install the completed coil over , set the car down, check it out then do the other side.
This is now my 7th attempt but I have it right now so it will not take long for the other side. I will then fabricate and install a rear sway bar then move to the front for a complete going over.
I will use a coleman sway bar with splined ends. It will all be custom machined parts.
would a modification like the c-4 with two forward pick-up points reduce the radical toe changes we get? i understand how that could be really undesirable but it seems the inherent negative camber gain through compression would be advantagious under hard cornering. if the toe was relatively fix and, say, a 6-link type system that still incorporated the camber gain be superior?
while i was at it, i took a look at the front again and it appears that there would be a way to fabricate new upper a-arms with inner pivot points 1.5-2" lower than the original. the biggest obstacle will be some form of a bracket adapting the new mounting points to the frame without major surgery.
As for a c4 type trailing arm setup, it''s not the 2 rods that give the benefit, it''s the 2 hinge points. The 2 rods are there to keep the hub from moving, the 2 hinge points allow for the suspension to move and not change toe like on our trailing arm with 1 hinge point. the Neg. camber is good but not if it''s all over the place. I''m not sure what you''re running but the bushings in the rear all deflect a lot, as does the stock camber bracket. For a stock trailing arm setup, and taking the toe change for what it is, a sperical bearing in the trailing arm would be the best solution.
I've been following these two suspension posts with interest. I certainly can't contribute much, but I do enjoy the discussion.
I've had my trailing arms out, and I was surprised at how flimsy they seemed to be. Wouldn't there be some deflection just from the trailing arm itself?
BTW I put poly bushings in for the trailing arm and the strut rods in the back (while running rubber up front).
When you say the stock camber bracket deflects, are you referring to the piece that mounts to the differential that houses the eccentric cams for rear camber adjustment? Or am I confused?
Thanks, GM
Yes, the camber bracket is the bracket that mounts the camber rods with the cam bolts. The cam bolts don't hold their setting very well either if you do some hard driving, eliminating the cam bolts with throgh bolts and threaded rods (either spherical = best for rigidity; or rubber/poly ends) would be a better solution.
[Modified by Twin_Turbo, 10:21 AM 11/6/2003]
Guys remember the transmission points down so the rearend must point up an equal amount for zero vibration. http://www.streetrodderweb.com/tech/0203sr_driving/
[Modified by norvalwilhelm, 11:38 AM 11/6/2003]
I have a suspension analyzer and ran the stock vs Guldstrand numbers, and the roller center was raised several inches. The camber gain was also much improved, with a couple degrees of negative camber at full jounce vs positive camber. By moving the mounting holes down AND back, you can also add in more caster. What do you guys think? I will have to take a look at the Vette to see if the mount allows the room like the Camaro does.
Ken
On the camaro you have a straight piece of metal so cutting the top off it and moveing the hole lower is simple.
We would have to totally rebuild/modify this area. No simple cut and redrill.
If we could move the holes lower it would pull the top of the A arm in causing alot of camber gain with no way of making it back to close to 0 without longer A arms.
I just want the ability to quickly change the front ride height.
Norval, the upper arm mounting holes can be lowered a tiny bit, not much but a bit is possible. I however don''t think that tiny amount will bring much, the solution would be either remove the stock mount for an aftermarket mount or cut off the stock mount, chop off 3/4 inch or so and weld it back on.
The camber gain won't be a problem with adj. arms, just make the arm longer.
George, look at carrera shocks, they have a semi coil over for GM cars, the vette is not listed but I''d be VERY surprised if that setup does not fit our chassis. The lower control arm won''t be the problem, the shock mount won''t either. I think the only potential problem is the coil spring. Maybe they come in several lengths.
This is kind of off the main subject: But Norval have you come across any front coil overs that can be used with our stock A-Arms? I've been able to find aftermarket tubular setups.
George I haven't looked into front coil overs at all. I bought a set of rear and made my own mounts and I assume a little modification is needed for the front. I would never trust the 2 5/16 bolts on the front to hold the entire weight of the front end so if I went that route I would beef up this area.
Maybe after I get the rears working fine I will break down and do the front. I am not a fan of the buggy spring in the front.
I am quit happy with the front as it is but you do not have the quick height adjustment.
I run a 3 inch driveshaft since I twisted 2 stock replacements badly in just a few miles so my tunnel is full of driveshaft and doesn't have another 3/4 inch to be raised. I ground a bit of fiberglass as it is to clear the universals with the rear in the stock location.
If I pulled the motor and got in the engine bay I could easily cut out the stock A arm mounts and make/fabricate something different to lower them but with the motor in place I couldn't do a good enough job.
If the motor ever comes out agian then I will do it.
I am starting a spreader bar soon with welded in mounts but to do the inner mounts now is not something I will tackle.
I have been thinking about doing this to mine in the future along with the rear suspension from a C4. I know a couple companies will make an entire new chassis for our cars which the newer suspension will bolt up to. And if you have the equiptment it could be done yourself as well.
I realize this project would be very time consuming and expensive as well but I was curious if you guys are verry familiar with the C4's stock suspension. I know the C3's suspension isnt designed verry well at all and was wondering if the C4's suspension would be a big improvment or if youd find youself modifying the suspension from the C4 like were doing with the suspension in our cars.
Kevin
Also buying a C4 suspension has got to cost alot while modify any parts for me at least in relatively inexpensive.
Well not cheap if you consider the cost of the equipment to do the modification.
A C5 front and rear susp. would be totally awesome, especially the rear since it's double a arm too.
