Backfires through Carb when cold.
Old Nov 4, 2003 | 06:53 PM
lvrpool32's Avatar
lvrpool32
Default Backfires through Carb when cold.
I am running a small block with a 274 XE cam, DART cool can intake, demon carb (no choke), 10.5 to 1 compression (factory rating in 69) ported factory "camel hump heads with 2.02/1.60 valves. When the car is cold its pretty "stubborn" coughs and splutters until it gets warm, then goes liek stink!!!. I noticed today that it actually backfired through the carb when cold, so maybe the timing is a little out, in which direction should I adjust, advance it or retard it?
Nick
[Modified by lvrpool32, 7:32 PM 11/4/2003]
Old Nov 4, 2003 | 07:48 PM
dman535's Avatar
dman535
Default Re: Backfires through Carb when cold. (lvrpool32)
If the timing is retarded it can cause a backfire. I woulf guess you are having trouble with a lean backfire. Keep your foot out of the kitchen until the car warms up, or put a choke on it to help richen the mixture.
Old Nov 4, 2003 | 10:33 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: Backfires through Carb when cold. (dman535)
:iagree: I have no choke as well. I keep light pumping to keep raw fuel pouring into the mix until she warms up a bit.
Old Nov 4, 2003 | 10:48 PM
bigvette1's Avatar
bigvette1
Default Re: Backfires through Carb when cold. (LAvetteman)
In NY you need a choke unless this only a summer car. Put a timing light on it before you adjust the dist.
To Backfires through Carb when cold.
