Rear End TOE-IN SHIMS???
Old Nov 4, 2003 | 10:32 PM
Corvettelvr73's Avatar
Corvettelvr73
Default Rear End TOE-IN SHIMS???
I am going to be installing my trailing arm soon (i hope) but my old shims were so rusted they came out in peices. How do i measure the amount of shims to replace to get it somewhat close to aligned? Enough to get it to an alignment shop.
Old Nov 4, 2003 | 10:38 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: Rear End TOE-IN SHIMS??? (Corvettelvr73)
Assuming that the frame is fairly square in the backend, then the best I could tell you is to put an equal amount of shims on each side of the TA, and take it to an alignment shop.
The main thing is to get it looking right.
Old Nov 4, 2003 | 11:31 PM
redvetracr's Avatar
redvetracr
PS: Toe shims are still available from GM a little pricey but they have them.
...redvetracr
Old Nov 5, 2003 | 09:54 AM
Tom454's Avatar
Tom454
Default Re: Rear End TOE-IN SHIMS??? (redvetracr)
I have a whole box of OEM GM shims (non-stainless) since I do a lot of these... but I would opt for the stainless ones available from the aftermarket suppliers.
I hate rust.
It is the enemy.
See what living in the snowbelt (saltbelt) does to you??
EDIT:
PS.... I agreed with the first response to your post... so I figured the question had already been sufficiently answered so I didn't bother to restate the obvious....
You can't accurately align a car with a ball of string and a compass. The tolerances are too small and critical. You need some form of very accurate equipment, whether professional grade or home-made.
Tom
[Modified by Tom454, 2:06 PM 11/5/2003]
Old Nov 5, 2003 | 11:07 AM
Corvettelvr73
Default Re: Rear End TOE-IN SHIMS??? (Tom454)
I have some stainless shims from vette brakes. Thanks guys for your input.
Old Nov 5, 2003 | 12:33 PM
GTR1999's Avatar
GTR1999
What I did to get the rear arms close was to have the fornt wheel straight and used a line to run between the front and rear studs. I used the frame as a measurement reference. Then used a 2' level on the rotor hub with a sissor jack under the shock mount to level the arm and adjust the camber. I don't know how close it is but it looks a lot better then the way it was adjusted from the last shop.
Norval uses a laser to align his car but I'm not sure on the way it's setup?
Gary
Old Nov 5, 2003 | 01:14 PM
vettery's Avatar
vettery
Do you wounder some times if any one is actually READING your post?
Guesstimate the total shim thicknesses you had before and install the new shims in the same locations. With the car's weight on the rear suspension, get back and :skep: eyeball down each side of the car at the height of the wheel center line. If it looks outa whack, it probably is. Adjust shim thickness/location accordingly and drive directly to the alignment shop. :hurray:
To Rear End TOE-IN SHIMS???
