I want a 6 link!!!
supposedly makes them - got the info after researching that same
link on Corvette FAQs.
I've been doing more research - have found the ball joint rod ends
and female threaded rods (threaded tubes) are available at
McMaster Carr (www.mcmaster.com) for around a couple hun $.
Do a search on ball joint ends and look at all the pages - they're available
in a variety of sizes and even in stainless.
I've figured out a way to duplicate the geometry on the FAQ article
that has the pictures (basically the lengths of the upper and lower
strut rods and the mounting locations).
Next spring I'm going to take a shot at fabricating my own.
macxx1@excite.com
The hardest part is the rearend must come out to remove the clips, old wore out yokes work fine for this.
An easy way out for the top inner mount is weld a stud unto the crossmember.
Anyone with a welder could do it their self.
For someone who really wants to do it and is not just fishing I would give them all the dimensions and pictures but not before they are actually going to do it.
I have the system and love it. It makes rear toe adjustment and simple deal along with camber changes and it keeps the wheel planted squarely on the ground throughout the suspension travel.
This is one of my trailing arms with the upper 6 link strut attached.
Brutus has alot of pictures of his 6 link and he used alot of stock parts.
[Modified by norvalwilhelm, 8:14 PM 11/5/2003]
My plans are to put a 2x2 tube upper crossmember between the rear frame rails to attach the upper link. It will also strengthen the rear rail area.
With the batwing relocated up it will lower the CG and as Norval says remember to check driveshaft alignment.
Your car is stiff with the front member you added, I was impressed with it when I was in Vegas last year. I would further your frame trussing with a roll cage and probably use the Structural Foam we discussed after welding and gusseting every possibility. Jim
I'd like the pictures and information. Since I was unable to purchase the 5-link from guldstrand for a '81 unit, I've been thinking about your 6-link setup. The problem I may have is with mounting the link to the aluminum cross member in my car. I'm just getting started on putting the suspension in, so now is the time for me to do it. Is there any area of suspension geometry that the 6-link does not address?
Mark
[Modified by 81vette, 7:24 AM 11/6/2003]
That 13.5 length is center to center of the upper rod.
The inner mount must line up with the lower rod plus the yoke. It is critical to get the inner mount properly located.
I removed the clips and ground the yokes down to make sure they do not contact the pin.
With the six link installed without the spring i moved the rear wheel through a complete range of travel and the yoke moves in and out of the rearend alot so it is important that the yokes do no hit the pin or binding of the rear suspension could damage parts.
I also put a magnetic protactor on the brake rotor and it maintained the same camber throughout it's total travel.
I will check toe changes next week after the paint dries on my new coil over setup. Before the springs are installed I will use the bump steer gage on the rear to check toe change throughout wheel travel.
I believe in the 6 link and other then a little fabricating/welding can be easily put together for under $100.
The lower strut rod must be parallel to the driveshaft and this can cause and interference with the exhaust system where it passes under the rearend.
Mark
Mark I don't know. I liked the idea of not having the half shaft as part of the structure. I wanted it to strictly transmit power . I also wanted to get rid of the yoke play comming into it.
The upper and lower strut rods, 5/8th heim joints and the adjustability of the setup appealled to me. Toe/camber changes are effortless. The trailing arms have a good pivot in the front and with the upper and lower strut rods it becomes alot more rigid and no camber change which might not appeal to some.
Coleman sells the strut rods cheap along with heim joints so it just involves fabricating and welding mounts for the rods.
Like I told clutch dust the upper rod is 13.5 center of heim to center of heim with the inner upper mount located in a line with the lower strut rod and a certain spot of the yoke.
I will try to find the article that I made a hard copy of showing testing done on the 6 link.
I have had mine for at least 2 years and have found nothing negative about it and lots positive.
I have installed coil overs so it becomes even more important to stabalize the top of the trailing arm.
GENE
I will weld mounts on the front towers and run a bar right close to the water pump.
It seems too good to be true that such a great system can be put together so cheaply.
Edit: Forgot that you mentioned Brutus, who is this? :confused:
[Modified by RUXperienced, 1:42 PM 11/6/2003]
Here is the 6 link I made.
and this is the spreader bar bracket where I tried to centralise the bar more for a better spread of load at the mounting points as Gary has alluded to.
Also, how much in-out halfshaft movement is there throughout travel?
Thanks :chevy
Chris
Thanks :chevy
Chris
