Rod bearing question
Old Nov 7, 2003 | 09:36 AM
ImBatman's Avatar
ImBatman
Default Rod bearing question
What is the dowel hole for in the HD bearings? Is it worth the extra $1 per bearing?
CLE-CB743HD
Chevrolet: 1965-95 366, 396, 402, 427, 454, standard size, narrowed rod bearing with a dowel hole
CLE-CB743H
Old Nov 7, 2003 | 09:46 AM
Fevre's Avatar
Fevre
Default Re: Rod bearing question (BlackRat)
My guess is that the rod would have a dowel in it to keep the bearing from spinning. :confused:
:lurk:
Old Nov 7, 2003 | 10:23 AM
PRESSURERAT's Avatar
PRESSURERAT
The dowel holes are for aluminum rods which must use a dowel to locate the bearing. It has to do with the expansion rate of the aluminum.
Old Nov 7, 2003 | 10:29 AM
ImBatman's Avatar
ImBatman
Default Re: Rod bearing question (PRESSURERAT)
Great! Thanks guys.
Wade :thumbs:
To Rod bearing question
