ZZ4 head bolt pattern and torque specs
Old Nov 8, 2003 | 04:40 PM
Paul 73 Coupe's Avatar
Paul 73 Coupe
Default ZZ4 head bolt pattern and torque specs
Any ideas on where to get this info for the ZZ4? I imagine the torque specs would be different for aluminum heads than my stock L82. I looked online but no luck.
Old Nov 9, 2003 | 01:50 AM
Paul 73 Coupe
Default Re: ZZ4 head bolt pattern and torque specs (Paul 73 Coupe)
It is a sad day when a post on Andy Rooney gets 29+ posts and a guy asking a tech question gets bumped to the bottom. Maybe I should have asked a question in that thread.
Old Nov 9, 2003 | 03:15 AM
Shark Racer's Avatar
Shark Racer
Check in the C4 forum. They all run alum heads. I don't know the torque specs off the top of my head, but I'll take a look around.
-Steve
Old Nov 9, 2003 | 03:26 AM
Shark Racer
Default Re: ZZ4 head bolt pattern and torque specs (Pacin'California)
http://forums.corvetteforum.com/zerothread?id=454753
65Z01 offers a suggestion for the Trick Flow heads... should prolly apply in this case.
I also think it depends on what kind of bolts you're using...
-Steve
Old Nov 9, 2003 | 08:59 AM
Pete79L82's Avatar
Pete79L82
The torque sequence is the same as any small block. Start at the center between the two exhaust valves and work out from here. 65# of torque will work fine. Be sure to use lube on the underside of the bolt head and to use sealer on the threads.
Old Nov 9, 2003 | 02:03 PM
Paul 73 Coupe
Default Re: ZZ4 head bolt pattern and torque specs (Pete79L82)
This is what I was after. Thanks
To ZZ4 head bolt pattern and torque specs
