What would cause this?
Old Nov 9, 2003 | 01:07 PM
Skyhigh82's Avatar
Skyhigh82
Default What would cause this?
Ignition off
Ignition on
Old Nov 9, 2003 | 02:02 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: What would cause this? (Skyhigh)
My 79 did this. I never knew the reason why it did this. Anyone know?
Old Nov 9, 2003 | 02:10 PM
Quinn_Seipp's Avatar
Quinn_Seipp
Default Re: What would cause this? (Eddie 70)
my 80 does it too :skep:
Old Nov 9, 2003 | 02:41 PM
LiveandLetDrive's Avatar
LiveandLetDrive
Default Re: What would cause this? (Quinn_Seipp)
I don't know the exact reason, but the tach is electrical, when you turn the ignition off it just stops wherever it was at. If I knew how the tach worked internally, it would probably be more clear why. I've stuck it at 3000 just for fun. hehe
Old Nov 9, 2003 | 03:10 PM
Paul L's Avatar
Paul L
I know its completely normal for GM cars of that era but I do not know the reason it was designed that way.
Old Nov 9, 2003 | 03:17 PM
Spook's Avatar
Spook
Default Re: What would cause this? (paul67)
Seems like a short somewhere to me... It doesnt move with some throttle action? Maybe your tach is hooked up backwards to the dist?
I dun Knooo :nonod:
Old Nov 9, 2003 | 03:22 PM
Shark Racer's Avatar
Shark Racer
What's really fun is if you shut it off at fast idle and the tach "jumps". If it jumps past a certain point, it'll get stuck at 7000 RPM. Try that on for size - 7000 RPM at 0mph.
-Steve
Old Nov 9, 2003 | 04:34 PM
EDDIEJ82's Avatar
EDDIEJ82
Mine does the same thing :crazy:
Old Nov 10, 2003 | 09:24 AM
Skyhigh82's Avatar
Skyhigh82
So, I take it that this a is a common problem that everyone lives with?
Old Nov 10, 2003 | 10:12 AM
gliot1's Avatar
gliot1
St. Jude Donor '12-'13
It's normal for '78s. I know stock cars use a "tell tale" tach which allows them to see what the rpm was at if an engine failure occurs. But it seems to me that isn't he case on Vettes, because if the engine died the tach would drop and freeze until you turn off the ignition. I wouldn't worry about this......I have cehcked many tachs on that vintage and they all work that way....in other words it's not defective.
Old Nov 10, 2003 | 10:57 AM
77L82_4speed's Avatar
77L82_4speed
Default Re: What would cause this? (gliot1)
My 77 does this too, and drops to zero when the ignition is turned on with the engine off.
Must be a "design feature" of the electronic tachs. :)
Old Nov 10, 2003 | 01:00 PM
baja216's Avatar
baja216
Mine does that too. It acts alright when the car is running! :auto:
Old Nov 10, 2003 | 02:08 PM
Corvette_fetish's Avatar
Corvette_fetish
My '79 does it, and it never bothered me. Just accepted it as just the way it works. :crazy:
Old Nov 11, 2003 | 08:52 PM
KevinZ's Avatar
KevinZ
As we all know by now, this is an electrical, not a cable driven guage and when the key is off, no signal to make any change in its location, so it will just stay there untill it gets "juice" again. :) Hope this helps. (its a design thing) :crazy:
Old Nov 11, 2003 | 10:52 PM
TedH's Avatar
TedH
Same with my '80.
Old Nov 11, 2003 | 11:25 PM
blunsford's Avatar
blunsford
Get a Vette with a mechanical tack! :)
To What would cause this?
