How do I remove the hood latches?
Old Nov 9, 2003 | 01:42 PM
79VetteMike's Avatar
79VetteMike
Default How do I remove the hood latches?
I have a '79 and am in the process of painting the frame and engine compartment. I want to remove the latches(that hold the hood down) from the firewall. My question is: I know that I can remove the nuts from the top, but what holds the bolt? There doesn't seem to be a way to get to the head of the bolt, so what do I do? Thanks...
Old Nov 9, 2003 | 01:52 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: How do I remove the hood latches? (79VetteMike)
On my 70, I was not able to remove the bolts. The bolts stayed on the car. I don't know if the 79 is the same way.
Old Nov 9, 2003 | 01:55 PM
79VetteMike
Default Re: How do I remove the hood latches? (Eddie 70)
Do you know what holds the bolts in place? I'm wondering if they will fall out and if they will tighten back up when I put them back in. Thanks for the reply..
Old Nov 9, 2003 | 01:59 PM
Eddie 70's Avatar
Eddie 70
I am sure they will stay in place. Mine did not move and I had my latches out for over 10 months while I piddled around rebuilding the motor and front suspension. Loosen up the nut on all sides of the latches and when the latch is loose, make sure the bolts stay in place before finally removing the latch. This should help confirm if the bolts will stay in place.
Old Nov 9, 2003 | 02:14 PM
79VetteMike
Thanks dude!
To How do I remove the hood latches?
