Two Threaded holes in intake?
Old Nov 9, 2003 | 09:20 PM
homedawg247's Avatar
homedawg247
Default Two Threaded holes in intake?
i have the 2101 edelbrock intake. there are two threaded holes on the front. one is for heater port. whats the other for? the one right next to the water neck. the neck is really close to the hole so it can't be anything that would stick up much or it will hit the water neck. should i just block it off w/ a plug?
thanks
-Johno
Old Nov 9, 2003 | 09:34 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: Two Threaded holes in intake? (homedawg247)
thats the water temp sending unit...
[Modified by SIGNGUY, 9:39 PM 11/9/2003]
Old Nov 9, 2003 | 11:13 PM
homedawg247
Default Re: Two Threaded holes in intake? (SIGNGUY)
my sending unit doesn't fit the hole. should i buy one that fits? or is there more to it than that?
signguy- is that a wire or a tube coming off that? it loooks really big.
[Modified by homedawg247, 10:15 PM 11/9/2003]
Old Nov 10, 2003 | 06:05 AM
OkeeGuy's Avatar
OkeeGuy
i used the original unit...but i bought an adaptor piece at the hardware store...
here is a zoomed in pic of it...the white is Teflon tape...
the wire is covered with that ribbed plastic stuff...
[Modified by SIGNGUY, 6:12 AM 11/10/2003]
Old Nov 10, 2003 | 07:13 AM
Ybnormal's Avatar
Ybnormal
Mine has a plug in that hole www.angelfire.com/al/swhite7/temp.html
YBNormal...drive a vette
Old Nov 10, 2003 | 09:13 AM
redwingvette's Avatar
redwingvette
Default Re: Two Threaded holes in intake? (Ybnormal)
I leftthe sensor in the head and pluged the hole wih a brass pipe plug.
Old Nov 10, 2003 | 08:05 PM
OkeeGuy's Avatar
OkeeGuy
OOPS! i apologize!
after reading about it being in the head, it got me thinking so i just went out and looked and sure enough...mines in the head too!
i was confued because the one i showed a picture of IS a temp sending unit...
but it is for my elec fan...
sorry if i mislead you...
Old Nov 10, 2003 | 08:37 PM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
Loose the teflon tape, it can keep the sensor from grounding properly and mess up when it comes on or off.
Old Nov 11, 2003 | 07:31 AM
OkeeGuy's Avatar
OkeeGuy
Default Re: Two Threaded holes in intake? (Smokehouse69)
really???
hhhmmm...you have a point...i hadnt thought about that...
To Two Threaded holes in intake?
