Which speakers for C3?
Old Nov 10, 2003 | 04:09 PM
yankees1's Avatar
yankees1
Default Which speakers for C3?
I am wanting to update my dash speakers in my 72' C3. In the MidAmerica catalog is description of replacement speakers that will fit my current brackets. Pioneer 100 watt for 49.95 and Kenwood 60 watt for 79.95. I don't know why more watts cost ? Anyway any opinions as to brand and watts?
Old Nov 11, 2003 | 04:13 AM
rob75383's Avatar
rob75383
Default Re: Which speakers for C3? (yankees1)
I am also looking into a front speaker upgrade.
Although, when I tear my dash apart, I'm going to mock it up with some 6x9's to see if I can get 'em to fit there.
Has anybody fit any larger than stock speaker in the front??
I have two 12" with custom boxes waiting to be installed, and I still need something for the front that will be louder than the motor.
Old Nov 11, 2003 | 07:39 AM
FeedVaal's Avatar
FeedVaal
As a general rule, the higher the wattage a speaker is rated, the stiffer the cone material needs to be to withstand that higher power. This can have a direct bearing on the sound quality/range that speaker can reproduce. With most aftermarket decks being rated at ~25rms with a peak of 40-50 watts, anything over 60 watts is overkill unless your adding an amp into the mix. The best way to tell which speaker sounds best, is to listen to several side by side. Thats why most stereo shops have a wall with a selection of speakers mounted.
'75 383 ElkGrove, good luck with the 6x9 idea. That's going to take some engineering.
:cheers:
Old Nov 11, 2003 | 07:57 AM
GDaina's Avatar
GDaina
You have to match the Ohms...if you speakers are original, the ohms are not the same to speakers mfg. today.
Old Nov 11, 2003 | 08:34 AM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: Which speakers for C3? (GDaina)
do you want kick azz audio? If so go to a stereo shop and inquire about memphis car audio equipment.
Old Nov 11, 2003 | 08:40 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
When I did the stereo in my car I put in a few sets of 4x6s from Polk. I put one set in the dash and added a set in the kick panels.
Old Nov 11, 2003 | 11:43 AM
Scooter70's Avatar
Scooter70
Default Re: Which speakers for C3? (Sigforty)
I put Infinity Kappa 4x6 plates in my dash last winter and they rock. There's no way you're getting 6x9s under there though.... I put my Kappa 6x9s in boxes in the back. T-tops barely fit back there now, but they do fit.
Old Nov 11, 2003 | 12:16 PM
Cookwithvette's Avatar
Cookwithvette
Default Re: Which speakers for C3? (FeedVaal)
That's part of it. Voice coil winding, former, and cooling measures all affect power handling not to mention how well the spider and surround control the cone. Take a low power speaker and throw an excessive spike at it and you can literally shoot the voice coil clean out of the gap. When that happens it usually doesn't slip back down where it belongs, it gets hung up on the pole piece and destroys the speaker.
:cheers:
Old Nov 11, 2003 | 03:43 PM
HunterRose's Avatar
HunterRose
Default Re: Which speakers for C3? (Scooter70)
I used MB Quart 4x6's for the fronts and 6x9's in the rear. You do have to be very careful to keep in mind that there is _very little_ room under the dash on the driver's side, so you should measure the existing speaker depth and try to match your replacement speaker to that dimension.
I had to modify the MBQ's to fit, and believe me, even with all the material I removed, it was a _tight_ fit. But they sound great, so it was well worth it!
As for power rating, don't worry so much about that as opposed to the frequency response of the speakers. There's a pile of junk out there being sold by nothing more than a watt rating, but that has NO bearing on how well they will sound! If you cannot look at a frequency response graph and a specification sheet for the speaker you are considering, DO NOT BUY IT!!!
Hope that helps some. :)
Tony
To Which speakers for C3?
