Holley carb question on throttle linkage
Old Nov 11, 2003 | 11:20 PM
Nomad78SA's Avatar
Nomad78SA
Default Holley carb question on throttle linkage
I put a Holley 4150 carb, mechanical secondaries and manual choke on my 78 vette and removed the q-jet.
I want to hook my cruise transducer up to it but the hole in the linkage is to small for the cruise stud to fit in. Is it alright just to drill it out some? Now the hole for the accelerator cable stud will also be to small for I had it in the other hole where it fit to start with. I bought a stud kit and the thread that will fit in the hole, the ball on the end is to big to go on the accelerator cable.
Should I just drill them out a little and be done with it or not.
Thanks for any help,
Neil in Tenn
Old Nov 12, 2003 | 12:12 AM
GDaina's Avatar
GDaina
Default Re: Holley carb question on throttle linkage (Nomad78SA)
You might want to call Holley tech support if no answer on the forum
