Custom Rear Swaybar
Problem: How to move the frame-pivots inward? Lacking a convenient cross member (the nearby crossmembers are too far forward, would require extremely short arms on the swaybar...still a possibility?) The only things I could think of are A: weld in a new crossmember just for this purpose. or B: design a "K" shaped swaybar like so:
Sorry for the bad drawing, but hopefully makes the point.
Would this kind of design be too weak, or bend in the wrong places? How less efficient do the diagonal arms make it?
I plan to make it tubular rather than solid for weight reasons, and ease of adding spherical end links.
All comments appreciated :cheers:
Chris
Edit: Image not working for me, maybe you'll have better luck. Picture a swaybar with diagonal arms on the ends, but the arms are moved inward, so some straight section sticks out.
It also just occurred to me that I could place a mount on the inside of the frame instead of the bottom, and have it hang down, using a more standard swaybar, with slightly diagonal arms.
[Modified by RUXperienced, 2:12 AM 11/12/2003]
MAtt
I bought my 3/4 from Vette Brakes and Products and it did not pit on my my car. The rear frame mounting point held the bar back far enough that you couldn't ever bolt it onto it's attachment points.
I finally realized that my larger rear spring was holding the mounting point further away and then i installed spacer blocks to lower the frame mounting point.
I've never designed anything for my car before, I'm curious how good my engineering instincts are. :yesnod:
-Chris
Coleman racing sells splined tubular sway bars any length for about $86. They are splined on the ends plus they sell the arms 16 inches long splined for the sway bar in straight and 30 degree. They also sell the mounting blocks.
I am going this route. I too want to try a rear sway bar this summer.
I always wished that sway bars were sold as % instead of diameter. It would make much more sense to me!
If you try using an existing bar and weld arms on it forget it. The weld will form martinsite and it WILL break.
If you go to the trouble of building your own bar get it heat treated.
Norval, thanks for the info, if I decide I need to go from scratch I'll remember to do it right :thumbs: I'm reading the metallurgy portion of Carroll Smith's Engineer to Win, so the options with steel types and hardening are starting to get more clear.
[Modified by RUXperienced, 5:06 PM 11/12/2003]
