AR 383 Update...
Old Nov 15, 2003 | 12:53 AM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: AR 383 Update... (GrandSportC3)
How are they rating their engines if it is the engine itself ( wihich I am assuming Gross HP) you can lose 15- 20 % through accessories and exhaust now you have your flywheel horspower ( Net HP ) drop another 15-20% for drivetrain and you get RWHP so 425 HP - say 35% = 277RWHP :D
Old Nov 15, 2003 | 08:12 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: AR 383 Update... (MotorHead)
The engines should be already rated and dynoed with the accessories for flywheel horsepower.. I'm pretty sure that - if you put a ZZ4 in a C5 (with manual transmission) - you'll end up with a 15 - 17% drivetrain loss and 18 - 22% with Automatic... It's the old technology drivetrain on C3's that cost you the horsepower...
Old Nov 15, 2003 | 08:49 AM
Marc80's Avatar
Marc80
I guess I should be happy with 280 RWHP from AR's 425hp 350. That is a34% loss of efficiency. The only other mods I can do to get more would be electric fan and electric fuel (also for cooler fuel) ...as far as I know. (since open headders won't work for my life, that is.
I AM happy with the engine. It is fast, it looks good, and it sounds and feels great! ...Oh yeah, and it was relatively cheap. AR racing has always been very helpful for me, too.
I do think I might have gone with the 383 if I did it over.
Old Nov 15, 2003 | 02:50 PM
MotorHead's Avatar
MotorHead
Default Re: AR 383 Update... (Marc80)
I know the ZZ4 is rated at close to flywheel HP(Net HP) ,which makes sense because it is GM, they do use a muffler system of some sort. So 355 HP - %20 drivetrain loss comes to 285RWHP which is in the ballpark of what I have seen personally from ZZ4' ( 260 -280RWHP).
If I was a crate engine builder I would try to get the most HP I could put of the motor meaning open headers no accessories etc. so I could sell the motor easier. Therfore I beleive most of the crate engines are rated at Gross HP.
If this is true then to compare the ZZ4 crate engine to other crate engines you would have to say the ZZ4 is well over 400HP.
Old Nov 15, 2003 | 02:53 PM
GrandSportC3
I guess that you have a TH400 Automatic Transmission :confused: :confused:
35% loss seems to be within normal range for that transmission.. If you have a manual transmissin - you are losing 10+% too much...
Did you dyno test with open pipes or with mufflers??? Even good Mufflers will cost you 15 - 20 RWHP...
Old Nov 15, 2003 | 03:00 PM
GrandSportC3
I don't think that most engines are rated with gross horsepower... I think that it's industry standard to rate them with the accessories.. but I'm not an expert...
My engine was rated 465 HP and I got 365 RWHP... If the engine would have been rated in gross horsepower - I'd have 15% accessories loss + 15% drivetrain loss.. Therefore - 365 RWHP would mean that the engine has 520 crank horsepower.. which would be 55 HP above the advertised horsepower rating... (520 HP - 30% (156 HP) = 364 RWHP).. I don't think that my engine was 55 HP underrated... I asked Mark (from AR) and he said that they dynoed the mule engine with mufflers (race mufflers) but not with open pipes. I didn't ask about accessories.. but I guess that they also had the accessories on the car... or I really got more horsepower than they advertised :confused: :confused:
Old Nov 15, 2003 | 04:20 PM
aharte's Avatar
aharte
No. Nearly all crate engines are rated gross hp. An engine alone cannot be rated with net hp because the builder doesn't know what accessories you're putting on, which exact exhaust, intake system, etc. If an engine is rated with net hp, then that number is not useful unless you run the exact same combination that they did. It wouldn't make any sense.
An engine builder could be dishonest, and advertise "net hp," but that's not what you're getting. He probably hooked up some very minimal accessories, and a nearly open exhaust to get a high number. Net hp is (correctly) advertised on new cars, and that's about it.
The 15% rule is really not a rule. Stop making it out to be. Maybe its reasonably reliable for net->wheel hp. I doubt you have any good information saying that there's a 15% loss from accessories - especially since everyone has different accessories, and certainly very different exhaust.
You also have much better results than most people from AR. Maybe other people need to do some tuning or maybe you got lucky?
Old Nov 15, 2003 | 05:47 PM
GrandSportC3
Default Re: AR 383 Update... (aharte)
I'm pretty sure that the main reason for my good results is that I run open pipes.. ANY STREET MUFFLERS WILL COST YOU AT LEAST 20 HP OR MORE!!
A mechanical fan will cost you another 10 - 15 RWHP...
I don't run a mechanical fan nor do I run mufflers...
Old Nov 15, 2003 | 06:12 PM
Twin_Turbo's Avatar
Twin_Turbo
:iagree:
I see pople messing with loss figures all the time, they are so unexperimental you can mess with them and get the HP figure you want.
Old Nov 15, 2003 | 06:28 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Re: AR 383 Update... (Twin_Turbo)
unexperimental ? :lolg: Sounds like a dull relationship and I guess you could say an undeterminable loss. :eek:
Old Nov 16, 2003 | 02:58 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: AR 383 Update... (cardo0)
yeah yeah, so it ain't a correct english word. You may laugh about it when you can write and speak dutch at the level I speak english okay! :nonod: :sad: :yesnod:
[Modified by Twin_Turbo, 2:04 AM 11/16/2003]
Old Nov 17, 2003 | 04:11 PM
dath's Avatar
dath
Don't worry about your English writing skills, they are better than those of half the native English speakers on this forum. :)
As for loss figures, I didn't mean to start a storm of conversation/arguement... I should have said ~30% probably for *my* setup, but it may be more. My end goal as far as accesseries and other power eaters follows:
1 - Electric fans
2 - Electric fuel pump
3 - Mufflers with electronically actuated cutouts
I'm just trying to decide what size exhaust pipe and which mufflers would be a good compromise when I'm tooling around town and don't want to go deaf. I'm not building a race car, I'm building a car that I can race. From that stand point, I'd love to go to a manual transmission sometime in the future, but just don't have the money to do it now... But I'm digressing:D
Old Nov 17, 2003 | 04:16 PM
  #33
Fevre's Avatar
Fevre
Default Re: AR 383 Update... (dath)
:iagree: Yours is gooder than mine most of the time. ;)
Old Nov 17, 2003 | 04:36 PM
  #34
GrandSportC3
1 - Electric fans
That's probably a 30 RWHP gain right there :yesnod: :yesnod: :yesnod:
Old Nov 17, 2003 | 04:47 PM
  #35
stingraynick75's Avatar
stingraynick75
Hey dath it's been a while and I've been meaning to give you a call but time has been a factor, glad the ball is still rolling let me know if you need help with the install, BTW what are you going to do with your old carb???, I'am looking for a 74 and eariler for the heads I want. :cheers:
Old Nov 17, 2003 | 05:43 PM
  #36
dath's Avatar
dath
1 - Electric fans
I hope so:D Right now anything I do is going to give my car a significant boost. Fastest it has moved in over a year is still probably 1mph, maybe two when I get a hand pushing it:)
Nick: No plans for the my old quadrajet. It is not original, I think it came from a '75 truck if I recall correctly. Lets talk, I may need an air intake fabbed up, the carb is yours (if you want it) if you can help me with an intake when the time comes:)
