sequence for dash install?
Old Nov 13, 2003 | 04:18 PM
Todbo's Avatar
Todbo
Default sequence for dash install?
Anyone know the sequence - drivers , center , pass , & then top? I looked thru the archives but no answers. Thanks
Old Nov 13, 2003 | 04:20 PM
dmrodco's Avatar
dmrodco
Default Re: sequence for dash install? (Todbo)
IF I could get a do over I would do it Top drivers side pass side then center good luck
Old Nov 13, 2003 | 04:28 PM
Rolling Thunder's Avatar
Rolling Thunder
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '03
Man I have not seen you around in a while. How are you doing?
I would go with center instrument panel, drivers lower, then top (the top bolts in from the passenger side underneath) and finally the passenger side.
No mater how you do it, it ain't fun!
Dave
:cheers:
[Modified by Rolling Thunder, 3:30 PM 11/13/2003]
Old Nov 13, 2003 | 05:08 PM
Todbo's Avatar
Todbo
it's like any corvette project - there's two ways to do it Hard , and Harder or you might be on the liquid measurement scale 1 beer vs. 6 beers :cheers:
Old Nov 13, 2003 | 05:11 PM
GTR1999's Avatar
GTR1999
I would go top pad,left dash panel,center gauge panel, console, right panel.
I have to do this on 2 cars now. They're already apart.
gary
Old Nov 13, 2003 | 05:26 PM
Bobchad's Avatar
Bobchad
Default Re: sequence for dash install? (gtr1999)
You have to put the left lower in first. With the top pad off, you then have access to the wires, etc, behind the dash. Center or top could go on next with the right lower last.
Old Nov 13, 2003 | 09:16 PM
Spook's Avatar
Spook
Default Re: sequence for dash install? (Bobchad)
The most important thing to remember is that all the wires go behind the dash! :jester
Old Nov 13, 2003 | 09:27 PM
71vettman's Avatar
71vettman
I had the entire inerior out including the wiring harness. Because it was 2 years until I was putting the dash back i had to take the dash apart about 5 times untill i could remember how everything went. In my past disassemblies and assemblies ive found it easiest to install the top pad and then either the center cluster or driver side (assuming your tack and spedo are already in and hooked up. Every time the passenger side was the last piece on. As mentioned before there are alot of ways to do it. All of them are a pain in the butt.
good luck
Kevin
Old Nov 13, 2003 | 09:49 PM
markdtn's Avatar
markdtn
Default Re: sequence for dash install? (71vettman)
I did top, pass side, center, then left side. That appears to be different than the others. Worked great for me.
To sequence for dash install?
