Dynomax headers
Old Nov 13, 2003 | 06:32 PM
OkieVett's Avatar
OkieVett
Default Dynomax headers
I have decided to go with the Dynomax ceramic coated headers, some questions for those of you who have installed these. Any problems with the spark plug boots hitting the header tubes. Did you need a starter shield to keep the heat off. Is there a bracket required for the alternator on a 71 small block, if so do you have the part number. And last did you notice a power increase.
Old Nov 13, 2003 | 06:41 PM
OHSIXX's Avatar
OHSIXX
C2 of Year Finalist (performance mods) 2019
Default Re: Dynomax headers (OkieVett)
On my car: No alternator bracket needed and no heat shield. I used 90 degree boots and # 4 is real close, but not touching the header.
Be sure to use Stage 8 Fastners!
Old Nov 13, 2003 | 06:45 PM
SAC's Avatar
SAC
I have the dynomax. No problem with boot clearance nor did I use a starter heat shield. I have driven on a 100 degree day and had no problem with the starter. You need a bracket (2 pieces) for the alternator. I got mine from summitt - they will know what you need. The brackets didn't come with any bolts :mad I had to go get my own. You will need one for the alternator pivot and two to put the two parts of the bracket together. I had an H-pipe hooked up at the same time. It became quieter and a little more power. :hurray:
Old Nov 13, 2003 | 11:21 PM
munday's Avatar
munday
Default Re: Dynomax headers (SAC)
they are awesome, i like better than my hedmans
Old Nov 14, 2003 | 09:00 AM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I put them on my 71 over a year ago. They look and perform great. I did need a bracket to that sits just over the header for the alternator to bolt to. I think the bracket only cost like 20 dollars max. I cannot find the dynomax version of this bracket, but summit does carry it. Here is a picture of what it should look like from Hooker's website. http://www.holley.com/HiOctn/ProdLin...f10917HKR.html
[Modified by Sigforty, 8:01 AM 11/14/2003]
To Dynomax headers
