Question about Performer Intake ??
Old Nov 14, 2003 | 02:19 PM
stingraymax's Avatar
stingraymax
Default Question about Performer Intake ??
I am looking to build an engine but I need to know if i install an edelbrock performer RPM vortec Intake that it will fit under my stock hood (75'er).
Anybody that can help me ??
Thanks in advance.
Old Nov 14, 2003 | 02:38 PM
79Corvette02's Avatar
79Corvette02
Default Re: Question about Performer Intake ?? (stingraymax)
Perfomer, yes; Performer RPM (Air Gap)-no, not unless you get a drop-base air filter. Tons of guys have the drop bases and have the RPM's :thumbs: :cheers:
Old Nov 14, 2003 | 03:12 PM
stingraymax
ok thanks, Ill try to find a drop base...
Old Nov 14, 2003 | 03:25 PM
stingraymax
Ok one last thing...
If I would get a drop base air filter, would there be enough space between the hood and filter to put a 1" spacer between the carb and still clear the hood or is this asking too much ??
Old Nov 14, 2003 | 04:11 PM
79Corvette02
That might be asking to much. Maybe some other members have the spacer. Maybe you won't need the spacer though, depending on the combination you're using, the spacer may only get you a HP or two depending on other variables, so it may not be worth it. I'll let some other guys add their two cents though. :cheers:
Old Nov 14, 2003 | 11:47 PM
killervette666's Avatar
killervette666
Default Re: Question about Performer Intake ?? (79Corvette02)
I have a performer RPM with a speed demon carb and drop base air cleaner under a stock L-82 hood and it fits fine, not a lot of clearance so i doubt ull fit in a carb spacer :cool: :seeya
Old Nov 15, 2003 | 03:14 PM
jaggeedfire's Avatar
jaggeedfire
On my 77 I have a performer with a 1 in. spacer and no drop base. Clears but Id like a little breathing room.
To Question about Performer Intake ??
