dot 3/4 vs dot 5 brake fluid
Old Nov 14, 2003 | 02:53 PM
jak71454's Avatar
jak71454
Default dot 3/4 vs dot 5 brake fluid
I am not positive what type of brake fluid I have in my 71. Is there an easy way to find out? I know you can't mix them and the brakes are working great so I don't want to flush the system. Thanks, Jim
Old Nov 14, 2003 | 03:06 PM
guppie's Avatar
guppie
St. Jude Donor '08
Default Re: dot 3/4 vs dot 5 brake fluid (jak71454)
jak,
I could be wrong but I believe it's marked on your caliper somewhere.
I would imagine it would be dot 3
dot 4 is usually for race cars and motorcycles
dot 5, I believe is synthetic
According to my owners manual for mine it's dot 3 :cheers:
[Modified by guppie, 2:16 PM 11/14/2003]
Old Nov 14, 2003 | 10:04 PM
Chris69's Avatar
Chris69
DOT 5 is purple colored (it's also silicone). Put a little is a glass jar with some water and it won't mix if it's DOT 5. DOT 3 & 4 will mix with water.
[Modified by Chris69, 10:04 PM 11/14/2003]
To dot 3/4 vs dot 5 brake fluid
