SAY IT AINT SO!!!!!!!!!!
Old Nov 14, 2003 | 06:28 PM
killervette666's Avatar
killervette666
Default SAY IT AINT SO!!!!!!!!!!
We running a 750 cfm Speed demon carb with a performer RPM intake on an otherwise stock L-82, BUT our carb is running FILTHY RICH, we called around and a bunch of people said that it is WAY TO BIG, i want to know if its possible to run the 750 without getting a supercharger or changing the rotating assembly, wer planning on getting cam and lifter kit as well as port matching the heads. ANY HELP WILL BE APRRECIATED :confused: :D
Old Nov 14, 2003 | 06:49 PM
bhmyers's Avatar
bhmyers
Default Re: SAY IT AINT SO!!!!!!!!!! (killervette666)
A 750 Demon is like a 850 Holley. Your carb is too big for a stock 350. You should be running a 650 or so. You can try to change the jets to 73/83 and maybe the power valve as well.
[Modified by bhmyers, 11:49 PM 11/14/2003]
Old Nov 14, 2003 | 08:43 PM
killervette666
Default Re: SAY IT AINT SO!!!!!!!!!! (bhmyers)
Were thinking of trading it in for a 625 Road Demon.. Wat do you think, will it provide enough power if we change cam/port heads? :confused:
Old Nov 14, 2003 | 09:12 PM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
why is a 850 Holley too big for a 350, but a stock Q-Jet is 850 cfm and they work just fine?
Given a choice i'd rather go with the carb with the big holes.
Old Nov 14, 2003 | 09:36 PM
Vetterodder's Avatar
Vetterodder
Active Streak: 90 Days
Under what conditions is it running rich? Idle? Cruise? WOT? While a 750 is more than a stock L-82 needs, it's not grossly over-carbing. Speed Demons are jetted more for a modified engine than for a stock smog motor so some adjustments may be needed. If the over-rich condition is just at idle, the solution could be as simple as adjusting idle mixture.
Old Nov 14, 2003 | 09:46 PM
killervette666
Default Re: SAY IT AINT SO!!!!!!!!!! (Vetterodder)
It running rich at all RPMs,are q-jets really 850? i find that hard to beliveve, would it be worth goin to 625 road demon?
Old Nov 14, 2003 | 10:00 PM
Spook's Avatar
Spook
Didnt lars just make a post on this very subject. Let me go look and I will link you to it.
Indeed Lars strikes again... good luck
http://forums.corvetteforum.com/zerothread?id=688640
[Modified by Spook, 10:01 PM 11/14/2003]
Old Nov 14, 2003 | 10:09 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: SAY IT AINT SO!!!!!!!!!! (Spook)
Quadrajets and square bore (Holleys) should not be compared on CFM's. Taks a look at the quads primary venturies, very small comapred to a Holley. You would need a much bigger ( CFM wise ) quadrajet to replace a 750 Holley. :D
Old Nov 15, 2003 | 05:17 AM
Larry B.'s Avatar
Larry B.
I hear this a lot.. "My carbs too rich"!... There is a difference between too rich(too much fuel to air ratio) and too much of the correct mixture. An incorrectly set up 200cfm carb can flood an engine and run so rich the engine will smoke black and foul plugs. Even a correctlly set carb that is too big shouln't do that. Granted, it may not perform to it's potential but it should run ok except maybe at WOT. I think you have a carb tuning issue. I don't know anything about the Demon carbs but they are still a carburetors and the same rules apply..
To SAY IT AINT SO!!!!!!!!!!
