Spread Bore To Square Manifold??
Old Nov 15, 2003 | 09:01 AM
Edzred72's Avatar
Edzred72
Default Square Bore To Spread Manifold??
I've looked in the catalogs but can't find a carb adapter that allows a square bore carb to be mounted on a spread bore pattern Performer intake. Does one exist????
Eddie
[Modified by Silvr77, 11:14 AM 11/15/2003]
Old Nov 15, 2003 | 09:59 AM
PRESSURERAT's Avatar
PRESSURERAT
Default Re: Spread Bore To Square Manifold?? (Silvr77)
If you have an edelbrock manifold you can use edelbrock part number 2732 which is a very thin adapter plate, like 1/16 thick. If you have a stock q-jet intake, you can use a mr gasket #1932 which is 1" thick.
Old Nov 15, 2003 | 11:40 AM
Edzred72's Avatar
Edzred72
Default Re: Spread Bore To Square Manifold?? (PRESSURERAT)
Thank You pressurerat. I bought a spreadbore pattern Performer cheap...and don't want to put my old Q-Jet back on or limit my options to spreadbores as I look at new carbs.
Thanks again
Eddie
Old Nov 15, 2003 | 02:56 PM
toddalin's Avatar
toddalin
Think I still have one of these adapters around here somewhere. If you need one, I can look through my parts.
Old Nov 15, 2003 | 03:09 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Default Re: Square Bore To Spread Manifold?? (Silvr77)
:nono: I think you can save your money slvr77. Every Edelbrock performer intake for the sb Chevy I know of accepts spread bore and/or square bore carbs. Yep, an enlarged plenum hole and extra set of bolt holes to fit either carb. :yesnod: Now the Performer RPM is different and won't accept both.
BTW those adapters work poorly and reduce performance. I'd change intakes first if at all possible. :yesnod:
[Modified by cardo0, 2:10 PM 11/15/2003]
Old Nov 15, 2003 | 04:09 PM
Edzred72's Avatar
Edzred72
Default Re: Square Bore To Spread Manifold?? (cardo0)
BTW those adapters work poorly and reduce performance. I'd change intakes first if at all possible. :yesnod: [Modified by cardo0, 2:10 PM 11/15/2003]
I'll have to check it again, but I test fit an Edelbrock 750 on the intake, and the primaries were binding. May have been misalligned.....Thanks
Eddie
[Modified by Silvr77, 3:10 PM 11/15/2003]
To Spread Bore To Square Manifold??
