My guess is it's 8",but the tape does suck.Put it on mine and it lasted just long enough to dial in my distributer recurve.(Putzed with it about a month.)I also tried the Proform Balancer cover,which lasted about 5 miles due to a clearance problem with my billet pulleys.
My suggestion is to get a sewing tape measure and actually measure the balancer.Whatever you come up with,divide by 10 and scribe a mark on the balancer clockwise from the factory mark.This will be 36 degrees.With the distributer vacuum disconnected,when you rev the engine to 3-4000 this new mark should be at 0 degrees if your timing is set right.
