plug wires. which ones??
Old Nov 16, 2003 | 04:17 PM
FNG's Avatar
FNG
Default plug wires. which ones??
hi guys. doing the winter tune up thing and need some input on plug wires. car still has original metal cover over the distributer and the wires run under the exhaust. well , headers are also going on this year , so will run over the rocker cover wiring. figure if i get some precut for the vette, they should only be 3 or 4 miles too long. sooo, any suggestions on what to use that will be closer in length to what i need?? maybe just some 77 chevy wires?? thanks for any help here fellas. regards, fng
Old Nov 16, 2003 | 05:13 PM
SHAKERATTLEROLL's Avatar
SHAKERATTLEROLL
Default Re: plug wires. which ones?? (FNG)
Easy question. Go with Taylor wires. :) No they are not precut. But that is very easy to do and you can route them like you want. :)
[Modified by SHAKERATTLEROLL, 10:14 PM 11/16/2003]
Old Nov 16, 2003 | 06:12 PM
FNG's Avatar
FNG
Default Re: plug wires. which ones?? (SHAKERATTLEROLL)
easy for you to say :D DUUHHHH, never entered my mind, must be having continued senior moments. thanks shaker. are they available at an auto parts store or do i have to order them?? thanks again, regards, fng
Old Nov 16, 2003 | 06:39 PM
homedawg247's Avatar
homedawg247
what about all the hype of MSD and Accel? i am very close to having mine running again. ihave a proform dist. pushing 50k volts i was also wondering what wires and plugs to go with.
thanks
-Johno
Old Nov 16, 2003 | 06:41 PM
AlwaysWave's Avatar
AlwaysWave
Cruise-In III Veteran
MSD Super Conductors, only 50 ohms per foot. :cheers:
Old Nov 16, 2003 | 08:25 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
I like both.. MSD 8.5 mm wires and Accel 8.8 mm Race wires...
Both perform very well...
Old Nov 16, 2003 | 08:41 PM
SHAKERATTLEROLL
Default Re: plug wires. which ones?? (GrandSportC3)
I am sure that all wires mentioned are very good. I just like Taylor wires. And I am very sure that MSD brand is also a very good brand so just take your pick. The only wire that I do disagree with is Accell wires. Never did like them. As far as the lock Auto Zone I do not think you can. But if there is a local speed shop I am sure they would have them or just order from your favorite online source. JEGS, Summit, or anywhere else that might carry them I am sure there are allot of people here with there favorite online source.
Old Nov 16, 2003 | 09:16 PM
petty44's Avatar
petty44
I just installed a set of Accel "red" super stock spiral wires 8MM 90degree, eazy to make to any length paid 39.99 at o'rielys :smash: they look good and run good for me :steering: bushog
Old Nov 16, 2003 | 09:28 PM
Wrecked82's Avatar
Wrecked82
When everyone is done with pushing Accel, Taylor, MSD, etc. go get some Magnecore and be done with the question.
Old Nov 16, 2003 | 09:43 PM
LAvetteman's Avatar
LAvetteman
St. Jude Contributor
Default Re: plug wires. which ones?? (Larry82)
I have had Accel, Taylor, and MSD on my 71. The Accels came with the car and were not fitted correctly as well as being 180 degrees and too close to headers, other than that at there age they leaked a bit. The taylors were "fit em all" kind, you crimp the ends, never again will I buy wires that are not allready made up, besides that they were leaking through the insulation within a year. Bought the MSD wires this past spring pre made with the variable boots, you bend the spark plug end to the angle you need. I am VERY satisfied with the MSD's and they were reasonably priced as well.
Old Nov 16, 2003 | 09:50 PM
SHAKERATTLEROLL
Default Re: plug wires. which ones?? (LAvetteman)
La vetteman. You lost me a tad there lol. On the Taylors I have used the only end you had to cut was the end that would go in the distributor cap not both ends.
To plug wires. which ones??
