engine compartment light bulb mount on my 82
Old Nov 17, 2003 | 08:57 PM
mannymen's Avatar
mannymen
Default engine compartment light bulb mount on my 82
the rubber grommets that hold the light housing in my 1982 corvette are all worn out. every time i close the hood, the housing falls out. i checked ecklers and Mid America but i could not find them in thier catalogs. where else can i find these rubbers and new screws?
Old Nov 17, 2003 | 08:59 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: engine compartment light bulb mount on my 82 (mannymen)
Try going to Ace Hardware. They have little rubber inserts that should fill the bill perfectly.
Old Nov 17, 2003 | 11:40 PM
Ric's80_4sp's Avatar
Ric's80_4sp
I believe those "well nuts" are still available from GM (part #14048060 $4.00 ea.)...1st try your local Lowes in the nuts/bolts section. I bought a pair a while ago for the exact same thing.
Good Times
ric
Old Nov 17, 2003 | 11:42 PM
mannymen's Avatar
mannymen
thanks for the suggestions. i will give the hardware store a try.
To engine compartment light bulb mount on my 82
