Ignition points question
Old Nov 17, 2003 | 11:33 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
Default Ignition points question
Okay all you old fossils who HAVEN'T converted to a wiz-bang electronic gizmo ignition...
GM made two versions of points. The standard set was part #D106P.
What was the GM part # for the heavy duty points????
Dep
Old Nov 18, 2003 | 05:22 AM
Larry B.'s Avatar
Larry B.
Default Re: Ignition points question (Dep)
D106HP. No longer made... D106P is not made either. All you can get are generic cheapies.. I stocked up on NOS delco points. If I forget to change points and they burn up (which is rare) I can replace them on the road in ten minutes, I've seen lots of problems from high tech ingition stuff that can leave you stranded. I know there are advantages but only when they are working correctly. Whatever you like.
[Modified by bluevetteman, 5:30 AM 11/18/2003]
Old Nov 18, 2003 | 07:29 AM
Pete79L82's Avatar
Pete79L82
Default Re: Ignition points question (bluevetteman)
Not sure who told you they are not available because they are. The DP106HP (1966294) is no longer available but the DP106P (12338659) clip type terminal or the DP106PS (12338660) screw terminal is still available from Delco or GM. They don't have as stiff of a spring as the DP106HP but I have used them on motors up 7000 RPM.
Old Nov 18, 2003 | 08:14 AM
BB68Vett's Avatar
BB68Vett
Default Re: Ignition points question (Pete79L82)
Dep, I converted from points to the Mallory Unilite module under the distributor cap. Best thing I ever did, BUT I keep a set of points and condenser in my car just in case. I agree that electronics are great but they can go out with no warning. At least with points you can kind of tell when the engine isn't running just right.
Old Nov 18, 2003 | 10:33 AM
DJ Dep's Avatar
DJ Dep
HA! I found it!!! I knew I read it somewhere and I should have dusted off my "How to Hot Rod Big Block Chevys" book before pestering you guys. The part number is P112HD. Points will go more than 8000 RPM without bouncing.
Not sure if they are still available though. Thanks for all the replies!!!
Dep
Old Nov 18, 2003 | 10:38 AM
DJ Dep's Avatar
DJ Dep
Default Re: Ignition points question (BB68Vett)
There's another dowside to electronic ignitions...you can "bump start" or push start a points-equipped car, and if the battery even has a tiny bit of juice it, the engine will kick over. With electronic ignitions there HAS to be a goodly amount of juice in the battery to provide power to operate the electronic ignition. Not enough juice and forget about starting it up at all without a jump.
Probably not a major concern nowadays with portable jump starters and road service coverage. Plus electronic ignitions have come a long way with relibility and accuracy. But still an interesting fact :)
Dep
Old Nov 18, 2003 | 11:08 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
Ain't technology grand? I wonder how many people running points carry around an electronic conversion just in case :lolg:
They can take my points when they pry them from my cold dead hands.....
Old Nov 18, 2003 | 12:01 PM
toddalin's Avatar
toddalin
It goes even deeper than that. My Mallory HighFire IV ignition box specifically warns AGAINST jump starting the car as it can burn out the delicate electronics. I one time several year ago I had the car in the shop for quite some time and apparently this is Exactly what they did, and burned out the Mallory.
I use Accell high performance points to trigger the Mallory. Now if I put the car in the shop, or just need a jump from extended sitting, I disconnect the Mallory and insert the supplied by-pass jumper and unplug the ballast resistor by-pass wire. (The ballast resistor is not needed in the Mallory system because the point only trigger the box and do not draw any real current.)
[Modified by toddalin, 11:05 AM 11/18/2003]
Old Nov 18, 2003 | 12:21 PM
DJ Dep's Avatar
DJ Dep
Default Re: Ignition points question (toddalin)
It gets ever WORSE than that!!! Did you know that NASCAR uses MSD boxes and they ALWAYS have TWO boxes installed in the car because it is COMMON for one of the boxes to fail!!! And they aren't using the "cheapie" model...they are using the big $$$ version!!!
Dep
Old Nov 18, 2003 | 12:27 PM
Bad-79's Avatar
Bad-79
Good God Man why would any-one bother with points these days with all the options in the marketplace. Convert and be done with it.
Old Nov 18, 2003 | 12:43 PM
DJ Dep's Avatar
DJ Dep
Default Re: Ignition points question (Bad-79)
I'll take a stab at that question! Let's see....
#1 They are easier to diagnose if there is a problem.
#2 They are cheaper to replace and easier to install.
#3 They are easy to adjust.
#4 You can carry a spare in your glove box if there ever is a problem
#5 The distributors for them cost MUCH LESS than electonic ones.
#6 You can buy them at ANY local auto parts store (if you can find a clerk who is above the age of 30 ;)
#7 With the right set they can give you as good a performance as an electronic ignition. I KNOW there will be a bunch of replies to that one! ;)
#8 Personal reason....I LIKE installing them and seeing/feeling the performance increase when I drive.
If I left any off feel free to add to it...or to slice and dice me :D
Dep
[Modified by Dep, 11:46 AM 11/18/2003]
Old Nov 18, 2003 | 04:37 PM
Larry B.'s Avatar
Larry B.
Still being available and not being made are two different things. While there may be some points in the Delco system, the new Delphi conglomorate is no longer making a lot of stuff that they used to. Many things we use may be hard to find in the future. Just check out NAPA for points... Their on-line catalogue doesn't list ANY available. If an item doesn't sell... conpanies stop making it. Good business sense.
[Modified by bluevetteman, 4:43 PM 11/18/2003]
Old Nov 18, 2003 | 05:04 PM
DJ Dep's Avatar
DJ Dep
Fortunately, aftermarket suppliers take up the slack nicely. I found a TON
of GM points here...
http://www.autopartsgiant.com/cj/?AI...129&PID=942610
...including heavy duty hi-perf versions. Considering the number of cars that were made with GM points since they started installing the V8 point versions, I think it's safe to say in MY lifetime I'll never have a problem getting them.
Dep
Old Nov 18, 2003 | 05:39 PM
Paul L's Avatar
Paul L
Accel 8104 is a good high performance replacement.
GTR1999's Avatar
GTR1999
Maybe I missed it, but what are the rpm ranges of the points you looked at? I remember the old mechanics not liking the HD sets with the heavy spring rate because they said it worn down the cam block faster?
Maybe it's a good idea to stock up now,I have a couple extra distributors might as well get the points,rotor,cap,and condenser too. Hows the pricing compare to local stores?
Thanks,
Gary
Old Nov 18, 2003 | 05:44 PM
DJ Dep's Avatar
DJ Dep
Default Re: Ignition points question (gtr1999)
gtr1999: Go with the points that Paul67 suggested. Accel points are good for above 8000RPM and don't wear down the rubbing block as fast as most others. I think either Summit or Jegs has them.
Thanks for reminding me Paul!! :thumbs:
Dep
Old Nov 18, 2003 | 06:05 PM
DJ Dep's Avatar
DJ Dep
Here's where to get the Accel points;
http://store.summitracing.com/produc...earchtype=ecat
Dep
Old Nov 18, 2003 | 07:55 PM
Paul L's Avatar
Paul L
No problem. They were suggested by the NCRS people (Yes!) as current AC Delco replacements are Made in...wait for it...Mexico (not China) and not up to snuff.
Old Nov 18, 2003 | 08:14 PM
DJ Dep's Avatar
DJ Dep
Default Re: Ignition points question (paul67)
Ahhhh...they must use the Mexican points in Tiajuana Taxis!! :lolg: :lolg: :lolg: :lolg: :lolg: :lolg:
Dep
[Modified by Dep, 7:15 PM 11/18/2003]
To Ignition points question
