Tuning article for Cross-Fire
Old Nov 18, 2003 | 07:44 PM
75 BBC Stingray's Avatar
75 BBC Stingray
Default Tuning article for Cross-Fire
Was doing a google search for info on EFI and gas tank mods, and came across this... Perhaps it is useful for someone...
http://www.corvettefever.com/techarticles/4688/
Corvette Fever
Tech Articles
Tuning the Forgotten EFI System
Ready, Aim, Cross-Fire!
By Ray T. Bohacz
Photography: Ray T. Bohacz
[Modified by 75 BBC Stingray, 7:57 PM 11/18/2003]
Old Nov 18, 2003 | 07:50 PM
Dalannex's Avatar
Dalannex
Default Re: Tuning article for Cross-Fire (75 BBC Stingray)
For some reason i get server not found?????? :confused: :confused:
-Justin
That's strange, I deleted the /4688/ and hit enter, then went down to the article and clicked on it and it came up just fine and with the same address as the one you listed above, but when I click on the link above it doesn't work???? I don't get it. Nice article anyway...
[Modified by Dalannex, 6:52 PM 11/18/2003]
Old Nov 18, 2003 | 07:51 PM
75 BBC Stingray
Default Re: Tuning article for Cross-Fire (Dalannex)
-Justin
Don't know, still works for me...
Old Nov 18, 2003 | 08:07 PM
Twin_Turbo's Avatar
Twin_Turbo
The article is about identical to what the shop manual states. One thing though, there's an alternative to the angle drilling in the throttle bodies to get the idle stop screw plugs out. Just use a small angle drill to drill a hole in the cap and then use a punch or small pry to get it out. That way you won't molest the casting. Also, the synchro screw weld can easily be remnoved, just use a dremel or something similar to cut a small groove in the weld, then grab the collar on the synchro screw and carefully work it from side to side (may need some vice grips), the weld will break. Leaving the collar on makes the screw much easier to adjust, you can do it by hand. Without the collar you'll need a socket.
To Tuning article for Cross-Fire
