Battery Cables
Old Nov 18, 2003 | 10:33 PM
l2vette's Avatar
l2vette
Default Battery Cables
I just puchased new battery cables, they where listed for a 69. I have a 72 and it looks like the cable diameter is smaller. Does anyone know if there was a difference and which one was better??
:confused:
Old Nov 19, 2003 | 01:11 AM
Bearcat's Avatar
Bearcat
Default Re: Battery Cables (l2vette)
It's technically more complicated than that. The strand count is more important, because electrons travel on the surface of the wire, so more strands=more surface area. BUT, generally speaking, the thicker wire will likely be better. There is a tech article in the back of Hot Rod magazine in which Marlin Davis explains how to check the voltage drop of your electrical system. Thicker wire and good connections, he says, can account for more than a volt less drop, resulting in stronger starter performance and brighter headlights, etc.
Old Nov 19, 2003 | 10:04 AM
l2vette's Avatar
l2vette
Default Re: Battery Cables (Bearcat)
Does that mean there was an improvement in 1972 over the previous battery cables used?
Old Nov 19, 2003 | 10:29 AM
markdtn's Avatar
markdtn
Not sure about which years are better. I went to a big truck supply shop and ordered some OO (double aught) cables the right length for mine. I think you can also order them from NAPA. I ended up with a truck top-stud type cable end (picture a 3/8 stud off the top of the battery) and had to use a marine conector to adapt to automotive top-post. With a little forethought I could have had them made for automotive top-post. This way there are no splices and you can get a high-quality, correct length cable. If it will last 1,000,000 miles in a big truck, it will outlast our cars.
To Battery Cables
