How do you CC an intake port??
Old Nov 19, 2003 | 12:56 PM
blunsford's Avatar
blunsford
Default How do you CC an intake port??
Do you do it with the valve in place or is there another way? I know the valve stem takes up some room so I'm not sure if the intake port volume includes the valve and stem.
With my 2.25 valve in place it takes up 252cc. Yeah, I know that valve may be a little overkill with oval ports, but they're there.
Old Nov 19, 2003 | 02:00 PM
burners's Avatar
burners
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: How do you CC an intake port?? (blunsford)
CC it with the valve installed. You are really just comparing port to port to equalize things. Obviously you want the maximun amount of flow with the smallest port possible.
Old Nov 19, 2003 | 09:03 PM
blunsford's Avatar
blunsford
Default Re: How do you CC an intake port?? (burners)
I'm trying to figure out what size the intake runners are - not if they're uniform. I've already done that.
I assume you subtract the size of the valve stem when sizing the intake runner???? About how much to I add to the intake runner size to take into account the valve?
Old Nov 20, 2003 | 08:40 AM
blunsford's Avatar
blunsford
bump
Old Nov 20, 2003 | 08:54 PM
Pete79L82's Avatar
Pete79L82
You do not subtract the volume of the valve stem. The valve is in place when the head is in use on the motor so when you cc the runner with the valve in place it gives you the actual usable cc. Hope that helps.
[Modified by Pete79L82, 7:55 PM 11/20/2003]
Old Nov 20, 2003 | 09:58 PM
Red69's Avatar
Red69
Default Re: How do you CC an intake port?? (Pete79L82)
Dumb question - what a runner?
Old Nov 20, 2003 | 11:19 PM
blunsford's Avatar
blunsford
Default Re: How do you CC an intake port?? (Red69)
RED69 - The runner is the "tube" that runs inside of the cylinder head from the intake manifold to the intake valve and from the exhaust valve to the exhaust manifold. The only stupid question is the one that's not asked.
Now, I agree that that is the way to determine the usable runner size. But I wonder if when Edelbrock or anyone else advertises their runner size if they include the valve. That means that a simple valve change would change the runner volume.
Old Nov 21, 2003 | 07:34 AM
Pete79L82's Avatar
Pete79L82
I am not sure about Edelbrock, but I do know the top quality head manufactures like Dart, Brodix, GM, World use advertsed numbers that are with a valve in place. Because they are castings the volume from port to port will change but in general they will be within 1 or 2 cc's of advertised. Advertised numbers are an average of all the ports on the head.
If you do not want the valve included then you have to cc the port "backwards", meaning that you will fill the runner from the bowl rather than the intake face. Make a blockoff plate for the intake face of the runner, use a heavy grease to seal the valve guide and fill the runner from the bowl area just up to the 45 degree valve seat. That will give you the maximum cc volume. Do all four ports on the head to come to an average volume.
Pete
[Modified by Pete79L82, 7:01 AM 11/21/2003]
Old Nov 21, 2003 | 08:24 AM
blunsford's Avatar
blunsford
Thanks, I just wanted to know how my stock ported heads compared to aftermarket heads.
To How do you CC an intake port??
