Where does the factory put the ground strap from engine to frame?
Old Nov 21, 2003 | 06:59 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Default Where does the factory put the ground strap from engine to frame?
I cannot remember where this was, I think it was on the passenger side, attached on one side to the starter motor brace, but where did the other end go?
Old Nov 21, 2003 | 07:21 PM
Spook's Avatar
Spook
Default Re: Where does the factory put the ground strap from engine to frame? (7t2vette)
One end goes to the motor mount frame component on the passenger side. The other goes to the block somewhat infront of the starter.
Old Nov 21, 2003 | 07:54 PM
Mr D.'s Avatar
Mr D.
Default Re: Where does the factory put the ground strap from engine to frame? (Spook)
RH frame motor mount, aft side and the other end bolts to the motor mount at the engine.
Old Nov 22, 2003 | 04:41 AM
Chuck Gongloff's Avatar
Chuck Gongloff
Active Streak: 90 Days
On my 69, the ground cable goes from the brace on the rear of the starter motor to the right hand frame "motor mount" recess. You should be able to find the location in your AIM. MIGHT be different for your year. :) Chuck
Old Nov 22, 2003 | 08:00 AM
7t2vette's Avatar
7t2vette
Default Re: Where does the factory put the ground strap from engine to frame? (Chuck Gongloff)
Thanks guys, thats where I'll put it!
To Where does the factory put the ground strap from engine to frame?
