I've had my vette for 2 yrs, and just found a partial parts list stuck under the driver's seat. It's all greek to me. Is anyone bored enough to take a look and see if any useful info is contained here? (the block and head numbers weren't on the list, I'll try and find them when I get some more daylight)
MFG Part# Name
TRW v-2470 2.02 In. Valve
TRW S-2469 1.60 Ex. Valve
Clevite 77 MS-909-P10 Main Bearing
Clevite 77 RB-663-P10 Rod Bearing
Federal Mogul H631P .040 Pistons
Federal Mogul E-251K Piston Rings moly 040
Blue Racer WG-5043K Cam,Lifters
TRW V-S-1008 Valve Springs
Comp Cams RP-1412-16 Roller tip rockers
Comp Cams RP-1412-16 Pushrods
TRW 50029 Oil Pump
GM 3855152 Oil Screen
Pioneer 851200 Head Bolts
ARP 134-6003 Rod Bolts
Moroso M-22070 Oil Pump Shaft
Pioneer 854010 Intake bolts
Moroso 65750 Fuel Pump Rod
Edelbrock 2101 Intake Manifold
Federal Mogul 1235M Cam Bearing
ARP 134-7101 Rocker Studs
Moroso 67900 Pushrod GUide Plates
GM 12341003 Valve Covers
GM Steel Crankshaft
GM cast#3970014 Hi-Performance 010 Block
GM 3970126 Heads
(heads have what appears to be a date code: \8 30 with a pointer @ 7o'clock)
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Re: Engine parts list, can anyone decipher? (76Frankenstein)
Pistons are flat top hypereutectic less than 10:1 compression with 64cc heads. Valves are good size meaning heads could be anything from fair to excellent performance, more info is needed. Can't find cam but could be mechanical / solid cam, sure you have the right numbers. Motor is a 350ci right ?
This is the Performer dual plane.....good for idle to 5500rpm and is a good street intake........
This is your cam........Blue Racer is part of Crane Cams.....the lifters and cams were sold as a package.....but I can't find any specs for it.......
GM Hi-Performance 010 Block
This may be referring to casting number 3970010, which was used from 69-79 on a lot of Chev cars and trucks including the Vette......this could be your original block......at any rate is been bored over 40 thou........
These are all good quality aftermarket parts and even without knowing cam specs or compression, I'd say you'd be making 300+hp......
you should be able to search the manufacturers websites or e-mail them for more detailed specs.....
The specs on a Blue Racer WG-5043K cam is 260/270 advertised 194/204 at 0.050 with .398/.420 lift. Generally refered to as their towing/rv cam. A lot of low end torque.
Thanks for the info, guys. The previous owner said he swapped out the motor about 7 years ago. He also said he had the cam changed in the new motor because he didn't like the one first installed. (about the only things I believe out of all the stuff he claimed.) So I'm pretty sure it is not the original. The block casting number is 3970014. The passenger side pad is smooth, no stamping visible. Will be checking head numbers later.
3970126 are 1967-70 327 heads with 1.94"intake & 1.5" exhaust valves.......
your date code \8 30 doesn't make sense........should be a Letter=month, 2 digits=day, 1 digit=year.....as in "A 14 9"........which decodes as Jan 14 1969...........please try again......
........the casting clock refers to the time it was cast during a shift.....
