Core Support Question
Old Nov 24, 2003 | 04:33 PM
piratemike's Avatar
piratemike
Default Core Support Question
I have a 72 Vette, 350,auto. My core support is shot and I need a replacement. I have found a core support for a 4 speed car. I can tell that the lower right bracket on the 4 speed car is in a different location than on the auto car. Other than that, are these supports the same? Could I relocated the lower bracket on the 4 speed core support to match that of my auto radiator.
Also, how could I mount a "universal" aluminum radiator in the 4speed support and add an extra trans cooler, If I decided to go that direction?
Any advice or suggestions would be greatly appreciated.
Mike
[Modified by piratemike, 3:34 PM 11/24/2003]
Old Nov 24, 2003 | 10:22 PM
piratemike's Avatar
piratemike
Default Re: Core Support Question (piratemike)
ttt
Old Nov 24, 2003 | 10:56 PM
mapman's Avatar
mapman
You might try:
http://www.dewitts.com/
He is a Forum vendor and is very knowledgeable, especially given your desire to fit a different radiator and remote transmission oil cooler. You might search the archives, I think several folks have fitted aftermarket transmission oil coolers.
Old Nov 25, 2003 | 06:25 PM
Tom@Dewitt's Avatar
0Tom@Dewitt
Former Vendor
If the lower right mount is moved over a little then it's the big block support. The only different between the 69-72 small block and bb is the location of the lower "u" bracket. You could cut it off and move it over 1.5" and you have a small block. Or I sell the brand new one for $278
As far as the radiator with automatic, I have one with a little ding in one of the tubes but other than that it new. $300 out the door.
Note that this small block radiator actually had a "dent" in the lower tube for clearing the suspension. Doubt the universal has that!
[Modified by Tom DeWitt, 5:27 PM 11/25/2003]
To Core Support Question
