motor advice
a cheap crate motor(350 $1200.00) and add cam and some good heads,
or GM 330hp 350vortech,
or just rebuild the old L82 350?
what ya think...i got about $2500 to work with
give me some advice to help me makeup my mind :banghead:
The only trouble with the AR engine is that you have to run circles if something goes wrong not that they wont back up thier engine. Grandsport is running 11s with one of thier engines. Who was it (DATH?) that had the issues? Either way I would ask both of em what thier impressions are I am sure others will chime in as well... tshort has one too i think? (Now I know he does)
I went the ZZ4 route myself even though it was more than I had wanted or had. I figure for a little while it will keep me happy as is. I got mine for somewhere just below 3200. The only real problem with that is the discrepencies you'll run into (waterpump, flexplate) but thier not to big a deal.
This is one of those questions that comes up pretty frequently on here and there are many opinions. I think everyone chooses the right route its just more a personal thing. Believe me I understand the money issue but I am sure you can strike the balance your looking for between power, performance, and reliability without totally breaking the bank. My strongest suggestion would be to check out AR a little more and hopefully you'll be able to decide from there. Good Luck...
Oh just a quick look will give you this AR RACING ON EBAY... I'm pretty sure if you call you can go whatever direction you need to.
[Modified by Spook, 4:01 PM 11/25/2003]
[Modified by Spook, 4:02 PM 11/25/2003]
My opinion is that rebuilds are more fun and more expensive......crate motors are a quick replacement and cheaper........
It depends on how much you want to get involved :cheers:
guess i was kind'a vage on my qus.
yes i can do all the work been there done that...
my bigest problem is were i live,been here 20+ yr's we left the door's open all the time year ago....now we have bars on the windows and gun at hand!!!
i cant leave anything out over night, it'll walk off...(open 2 car carport)
so i have to do every thing in one day or put every thing up,then drag it back out the next day if it's a long proj. i'ed move but being 1/4 mi. from work is nice!!
old L82 running good just old 110,000 mi. on it.
right after i got it had to put in a cam (old one had two lob's wore off it)
and a missing in act. pushrod (in oil pan i guss)
had 150 to 160 lb on every cilnder on compresion check so i put in a stock cam it.
was out ride'n and came up on a frend in a 97 prelude with a vtec and some mod's and at about 45mph we punched it ( i downshifed to 3rd) and he was pulling away slowly....so it's time for some more HP!
was saving for zz4, but was thinking i can get close to same hp and save a few buck's. then spend that on some side pipe's!!
think i'll just keep save'n for now thank all for your advice
:flag :steering:
