Windshield wipers stuck in the up position!
Old Nov 26, 2003 | 01:24 PM
Jaybo's Avatar
Jaybo
Default Windshield wipers stuck in the up position!
Am I looking at a switch or a motor?
The wipers had been hinky for some time, sometimes working fine, sometimes not. Last time I drove, they stuck in the up position. Any tips on shortening this ordeal? (I may have to wait on parts, as the budget is not what it used to be, but I want to fix this properly.)
Thanks!
:cheers:
Old Nov 26, 2003 | 01:48 PM
vettemack's Avatar
vettemack
Default Re: Windshield wipers stuck in the up position! (Jaybo)
Not sure which but be careful as when the wiper are not in the park position, there is still current flowing to the motor and it will discharge your battery. :eek:
Old Nov 26, 2003 | 02:45 PM
Jaybo's Avatar
Jaybo
Default Re: Windshield wipers stuck in the up position! (vettemack)
Oops! Better go check on that. Thanks for the heads-up! :thumbs:
Old Nov 26, 2003 | 03:23 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
Is the override switch on that causes the wipers to freeze in the position they are in?? I had some issues at first figuring out how the system worked, and what that **** under the dash between the two vacuum overrides does. It could also be the motor is locked up. I have had to grease the inside of my wiper motor a few times. Did you try tugging on the wipers to see that might undo the freeze?
Old Nov 26, 2003 | 06:47 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Windshield wipers stuck in the up position! (Sigforty)
Also sounds like it could have lost its ground and just stopped running. I don't know for sure but it is something else to look for.
Old Nov 27, 2003 | 11:37 AM
Jaybo's Avatar
Jaybo
Have to check, but it shouldn't be.
Tried tugging and got nowhere.
Old Nov 27, 2003 | 11:52 AM
AGVI's Avatar
AGVI
Canadian Events Coordinator
Wipers? We don't need no steenkin' wipers!!! :leaving:
Old Nov 27, 2003 | 01:18 PM
Jaybo's Avatar
Jaybo
Default Re: Windshield wipers stuck in the up position! (AGVI)
We do for safety inspections, mang! :lol:
Old Nov 27, 2003 | 10:43 PM
72GACRZR's Avatar
72GACRZR
you have verified the fuse is good? If someone turns them on ,do they make an attempt to move? you could try disconnecting the motor from the linkage and then see if the arms move or the motor runs.
You can try running 12 volts straight to the power peg on the motor, if it runs, check the switch.
[Modified by 72GACRZR, 10:44 PM 11/27/2003]
Old Dec 5, 2003 | 06:53 PM
Jaybo's Avatar
Jaybo
Default Re: Windshield wipers stuck in the up position! (72GACRZR)
I'll take a look at that this weekend. I just got out of the State Trooper academy for the weekend, so that's going on the list of "things to do while I can." Thanks for the info! :cheers:
Old Dec 5, 2003 | 07:10 PM
79 Bullet's Avatar
79 Bullet
Most probably a ground. Easy to check just touch metal surface on wiper to any good ground like engine and it should work.
To Windshield wipers stuck in the up position!
