82 Vacuum question
Old Nov 26, 2003 | 11:35 PM
jwatty's Avatar
jwatty
Default 82 Vacuum question
Having problems getting headlamp assemblies to raise on my 82. It appears that I need a just little bit more vacuum to get the lights up. Other than hoses, etc, is there anything related to the engine that needs to be changed to increase vacuum outpput from the engine? I have replaced the seals and boots on the actuator and checked all hoses for leaks....
Old Nov 27, 2003 | 12:08 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: 82 Vacuum question (jwatty)
Just guessing here, but try greasing them, also it could be one of the check valves. But what do I know, I have been finger lifting mine for almost a year now...
Old Nov 27, 2003 | 12:11 AM
turtlevette's Avatar
turtlevette
St. Jude Donor '03,'11
Default Re: 82 Vacuum question (Desertdawg)
I thought everything on your car worked. :D
the vacuum valves located just forward of the hood may be going bad.
[Modified by turtlevette, 12:22 AM 11/27/2003]
Old Nov 27, 2003 | 12:35 AM
Desertdawg's Avatar
Desertdawg
St. Jude Donor '09
Default Re: 82 Vacuum question (turtlevette)
Yep, I work on everything on my car, you got that part right.... :lol: :lol: :lol:
Old Nov 27, 2003 | 12:55 AM
jwatty's Avatar
jwatty
Vacuum valves??? I assume these are the relay units mounted near the lamp assemblies?
Old Nov 27, 2003 | 09:47 AM
terry82's Avatar
terry82
i would check the vac holding tank they will rust out then you will loose vacuume and not have enough to lift the lights . start at the vac hose that comes off the manifold with a gauge so that you know how much vacuume you are staring with then check it before it goes into the vac tank then as it comes out of the tank .
To 82 Vacuum question
