steering rag joint and box
Old Nov 27, 2003 | 03:48 AM
Turbo-Jet's Avatar
Turbo-Jet
Default steering rag joint and box
I’ve got a fair amount of play at the wheel. I suspect the rag joint. How do I confirm?
Do I need to replace just the flexible coupling piece, or do I need to replace lower column coupler w/rag joint.
How difficult is it to rebuild the steering box with the kit from Zip? I have access to shop tools and precise measuring gauges. And I like a challenge. :cool:
Old Nov 27, 2003 | 09:57 AM
noskillz's Avatar
noskillz
Default Re: steering rag joint and box (Turbo-Jet)
I rebuilt mine not too long ago.
First, there is a lash setting screw on the top of the box. Make sure you have this set properly before assuming the box is warn.
Second, the rang joint certainly wears out, but the steerin gear rarely does on the life of a vette. On my 69 the innards looked fine. I just cleaned it up, replaced the grease, seals, and one beraing a mashed while bolting it up, painted it and it was a s good as new. I don't know what is in the Zip kit, but a seriously doubt you need a full rebuild of the unit. Just be careful when reassmebling, the back bushing slips out of place and is very soft. If out of place it will mash when you tighten things down.
If you do rebuild, you don't need any special tools. The tolerences are not that close.
Old Nov 27, 2003 | 10:17 AM
Paul Borowski's Avatar
Paul Borowski
Cruise-In VI Veteran
St. Jude Donor '08-'09-'10-'11-'12
IÂ’ve got a fair amount of play at the wheel. I suspect the rag joint. How do I confirm?
With the car parked, have someone simply wiggle the wheel from side to side slowly. Watch both shafts on each side of the rag joint. If they do not "twist" together or move together at the exact same time, in another words, one shaft moves & one does'nt, here is where your play is and it needs either rebuilt or replaced.
Old Nov 27, 2003 | 08:17 PM
mark79,80's Avatar
mark79,80
If the idler arm is original, would replace. When it wears, you get play in
the steering wheel. When replacing the rag joint, would use the original
GM part which is still available. Do not use the universal kits available in
the Help section of chain auto parts stores.
To steering rag joint and box
