2 Broken Intake Manifold Bolts
Old Nov 30, 2003 | 02:36 PM
mvftw's Avatar
mvftw
Default 2 Broken Intake Manifold Bolts
I can't believe this happened. The front 2 intake manifolts bolts broke. The front ones on each side. All the rest came out OK. I bought Sears 'Bolt-Out', it's helping but still can't get the manifold off. The war continues... :cry
Old Nov 30, 2003 | 03:10 PM
comp's Avatar
comp
Default Re: 2 Broken Intake Manifold Bolts (mvftw)
good luck, don't get in hurry... if you apply heat ''don't'' over heat, propane
torch works good. been lookin' at those bolt extractors let use know how it
comes out.....
Old Nov 30, 2003 | 03:32 PM
mga1x's Avatar
mga1x
if enough of the bolt is showing at the top of the hole, you can have someone weld a nut to the top of it. the weld in the center of the nut should be strong enough to remove the bolt.
Old Nov 30, 2003 | 06:51 PM
mvftw's Avatar
mvftw
Default Re: 2 Broken Intake Manifold Bolts (comp)
Well the Sears 'Bolt-Out' didn't remove the bolt. I managed to get the intake out by pushing the back up till the front bolts bent forward. I also managed to remove one of the bolts with a vise-grip, but the other one doesn't want to play nice. I don't have a welder. What if I use a propane torch, should I heat the bolt and then let cool, or heat the head, or not use a torch at all? Last resort will be to drill & tap :(
Old Nov 30, 2003 | 07:08 PM
norvalwilhelm's Avatar
norvalwilhelm
Heat works great to loosen a stuck bolt but do not use water a trick that works on stuck bolts . Just heat the bolt and remove it hot, heat the head and bolt together then with vise grips work at it until the heat breaks it loose.
Old Nov 30, 2003 | 07:57 PM
comp's Avatar
comp
Default Re: 2 Broken Intake Manifold Bolts (norvalwilhelm)
try to heat the head around the bolt, you do have something to get vise grips
on it sounds like. back to heating around the bolt. spray pen. oil on it it will
kind of ''wick'' in BE carefull of FIRE, all the good pen. oils i use are flammable
do it a few time's ,,heat,spray,etc then heat and try to move bolt a nudge to
tighten can help, if no go apply heat to head, and a ice cube on the bolt, wear
gloves etc, just be carefull and take your time
Old Nov 30, 2003 | 08:26 PM
GDaina's Avatar
GDaina
heat and parafin wax...
Old Nov 30, 2003 | 09:47 PM
mvftw's Avatar
mvftw
Default Re: 2 Broken Intake Manifold Bolts (GDaina)
Where do you get parafin wax, a good auto supply store or like a home depot?
Old Nov 30, 2003 | 09:56 PM
JRD77VET's Avatar
JRD77VET
St. Jude '03-'04-'05-'06-'07-'08-'09-'10
You can get parafin wax at the grocery store. It's used to seal homemade jams and jellies,too.
:seeya Jeff
Old Nov 30, 2003 | 10:00 PM
CF6873's Avatar
CF6873
Heat the bolt itself and while it is red hot spray with WD 40. Be careful not to have the flame still there as WD is flammable. As the WD cools the bolt it will suck into the threads and with a little luck it will come loose. Good Luck, Craig
Old Dec 1, 2003 | 06:35 AM
GDaina's Avatar
GDaina
Default Re: 2 Broken Intake Manifold Bolts (CF6873)
I don't think you need to get the bolt red hot, just hot enough to expand and break the rust. I don't think spraying wd40 will accomplish much, all that will do is create a lot of smoke and the heat will evaporate wd40 instantly.
Old Dec 1, 2003 | 07:43 AM
CF6873's Avatar
CF6873
George, I learned about the WD40 method from a local engine builder who said he uses it to remove the oil galley plugs on the rear of the block. He said when using that method he can extract them with a 1/4" rachet with minimal effort. I thought it might be worth a try for other situations. Craig
Old Dec 1, 2003 | 10:50 AM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
:iagree: Repeat as many times as necessary :yesnod:
This is how I got the rusted/corroded/broken studs out of my exhaust manifolds. Just keep repeating the process until the bolt/stud will start moving with minimal pressure (less than it takes to break or strip it again).
The bolt and the manifold will expand/contract at different rates when heated and cooled, this helps break the bond between them and also allows the WD-40 gain a little more access into the threads. It works but will you should also plan on a little time for :cuss too.
Old Dec 1, 2003 | 11:24 AM
SnoDrgn's Avatar
SnoDrgn
From: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Had that happen earlier this year on my dad's car. remember... the bolts in the four corners are SHORTER :banghead: I ended up breaking off an easy out so I gave up and took it to a machine shop to have it fixed :leaving:
Old Dec 1, 2003 | 01:46 PM
mvftw's Avatar
mvftw
Default Re: 2 Broken Intake Manifold Bolts (SnoDrgn)
Not the answer I wanted to hear.... But I know what your saying. The four corners go into the water jacket, the bolts threads must be treated. I'm going to use a hand propane torch tonight...Hope I have good news tomorrow...
To 2 Broken Intake Manifold Bolts
