ramhorn exh. man. info
Old Dec 1, 2003 | 09:06 AM
comp's Avatar
comp
Default ramhorn exh. man. info
does anyone have info on the yrs. eng. etc that they used the 2-1/2 in. exit
on the ram horn exh. manifolds i don't have a thing on them. (don't need new) thanks
Old Dec 1, 2003 | 09:33 AM
lbell101's Avatar
lbell101
Default Re: ramhorn exh. man. info (comp)
I could be wrong but I thought the 2 1/2 inches were all pre-C3. Used on HP 327s.
Larry
Old Dec 1, 2003 | 10:06 AM
Smokehouse69's Avatar
Smokehouse69
Cruise-In VI Veteran
Cruise-In VII Veteran
I think Larry is right, the 65 or 66 model C2 was the last year to have 2-1/2" Rams horns.
Old Dec 1, 2003 | 10:19 AM
markdtn's Avatar
markdtn
Default Re: ramhorn exh. man. info (Smokehouse69)
:iagree: But they started back again with 2.5" outlets in the C4s. Not a rams-horn, but a nice shortie header that works great. I have TPI C4 manifolds on my 69, and I like them very much.
Old Dec 1, 2003 | 10:41 AM
comp's Avatar
comp
Default Re: ramhorn exh. man. info (markdtn)
any idea what they are worth used ? any other sbc. iron exh. mans. have
2 1/2 in. exits i don't know of any
Old Dec 1, 2003 | 12:25 PM
markdtn's Avatar
markdtn
I think 62-64 327 Hi-Po Impala or Chevelle is the same also, but they all bring premium money. I was going to use these to keep a stock look, but after watching them on Ebay they just went too high. I saw one at a swap meet once that looked like it had been laying outside since the 60s-looked like moon craters it was pitted so bad. He still wanted $150 for that thing. You can get the C4 ones for around $100 a pair, cut the AIR tubes off and weld the holes shut, or use the AIR tubes if you must have them for local emissions. Paragon has a repo for $210 if you don't mind grinding off the alternator mount, or $250 in a useable configuration.
Old Dec 1, 2003 | 02:17 PM
TTop Tony's Avatar
TTop Tony
Pace performance still sells them at $129 a side.
http://www.paceparts.com/product.asp...1=407&3=167449
Can't be all that bad I have a friend with a zz4 that pulls 13.4 in the quarter using these.
Old Dec 2, 2003 | 07:25 AM
comp's Avatar
comp
Default Re: ramhorn exh. man. info (TTop Tony)
that my opin. to i need a set for a truck, $100 plus a side sounds stupid right
now.. but if i think long enough........................
Old Dec 2, 2003 | 08:32 AM
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
I have a set of stock manifolds off an '89 350 Suburban if you're interested.
Old Dec 2, 2003 | 09:20 AM
comp's Avatar
comp
Default Re: ramhorn exh. man. info (1970 Stingray)
do they have a 2 1/2 in. exit on them????? all that i've looked at are 21/4
thats what i've got..
Old Dec 2, 2003 | 10:38 AM
Jughead's Avatar
Jughead
St. Jude Donor '09
No, not 2.5inch.
Old Dec 2, 2003 | 11:55 AM
comp's Avatar
comp
thanks , but i collected a few of the 2 1/4 '' i may end up getting the die-grinder out and try to open up a set to 2 1/2'' may need a little cast-iron
welding......
Old Dec 2, 2003 | 04:09 PM
stingry's Avatar
stingry
St. Jude Donor '05-'06
Try these.
(2.526 Inch exhaust manifolds)
Below is a list of casting numbers, side and year
3797901 LH, 62-63
3797902(1,2 or 3) RH, 62-64
3797942 LH, 63-64 and LH/RH 65
3846563 LH, 64-65
3856301 LH, 65
3856302 RH, 65
3880827 LH, 66-69
3880828 RH, 66-74
3880869 LH, 71
Try Contemporary Corvette for a used.
:cheers:
Old Dec 2, 2003 | 04:18 PM
comp's Avatar
comp
Default Re: ramhorn exh. man. info (stingry)
dude ,thanks now i have something to work with, i didn't think all the manifolds i've used yrs ago were all from the 60's
To ramhorn exh. man. info
