Oil turned dark quick [long]
MAtt
[Modified by pillowmeto, 8:16 PM 12/1/2003]
[Modified by pillowmeto, 8:26 PM 12/1/2003]
Good Luck!
a few hundred more mile's and change the filter again and really clean it up
inside
Thanks for the help
MAtt
Cheers,
Tony
acids into engine oil which, when sitting for an extended period,
can damage bearing surfaces.
Being it's dark - I'd agree that the additive probably knocked a
bunch of old crud loose - I'd say just before storage would be a
great time to change.
I guess they test the particles for which alloy they are, and can figure out where the wear and tear is.
I remember when I pulled my oil pan, the engine was dripping for at least 9 days. Oil has a way of coating surfaces and sticking around.
My current voodoo oil change ceremony is to drain all the old oil. Then, I fill her up with some cheapo NAPA brand oil, and run her like that for a week or so. THEN, I drain her again, replace the filter, and put in fresh quaker-state or some other "premium" oil. I was getting dirty sooty-looking oil, hours after the oil change.
Now, since I've been doing this wasteful, expensive, and time consuming oil change process, I find it hard to read the dipstick- the oil is sooo clear.
MAtt
http://www.synlube.com/motoroil.htm
Down the page under "magic dirt appears" is the following:
"SAE 5W-30 Exxon Ultra Flow motor oil. (was placed in a flask)
The Flask was placed on a asbestos pad in steel wire mesh and gas burner underneath was ignited.
The flame was adjusted so that the oil temperature INSIDE the flask was at about 300 ºF.
The experiment was monitored for TWO hours.
The fumes in the flask that were too heavy to escape through the silicone gas line, swirled about violently as the oil inside the flask bubbled, they eventually turned dark, and stained the inner surface above the fluid level in the flask.
The oil itself turned from honey like color to dark brown coffee color."
According to this site oil heated to 300 degrees will turn brown coffee color in two hours. So 300 miles would most likely do the same thing.
Probably nothing wrong with your oil.
Hope this helped,
David
[Modified by GATOR454, 3:13 PM 12/16/2003]
I didnt think anythign was really worng, i was jsut kind of confused. But with my engine never going above 150, given the oil is hotter than the water, and given the long period btwn changes im going to go with its getting all the bad crap out of my engine.
MAtt
