Replacement Under Dash Light Bulb Sockets?
Old Dec 2, 2003 | 06:59 AM
73Roadster's Avatar
73Roadster
Default Replacement Under Dash Light Bulb Sockets?
Does anybody know where I can find replacement light bulb sockets that go under the dash? I asked Lectric Limited and they have them but they only sell them as part of the dashboard wiring harness.
I hate to replace the whole harness to fix mine.
Thanks,
Ron
Old Dec 2, 2003 | 07:28 AM
mrvette's Avatar
mrvette
Default Re: Replacement Under Dash Light Bulb Sockets? (73Roadster)
I MAY have some hanging around, they are the metal tulip shaped snap flange things like my '72 I presume?? and one gray wire out the end...
how many you need??? another source is a locak older car junkyard....
GENE
Old Dec 2, 2003 | 08:47 AM
vettfixr's Avatar
vettfixr
I tried to find new ones for over a year with no success. I finally picked up a pair at Carlisle from Lectric Limited. The guy at the booth had an old harness in a box and cut the connectors off for me. If you can't find a used set you can get courtesy light kits from Painless Wiring that will do the job. They just won't be stock. Here's a link http://www.painlessperformance.com/catalogframe.htm
Look for Connectors and Pigtails, then look at the courtesy light kit. Good luck.
Old Dec 2, 2003 | 04:52 PM
76greg's Avatar
76greg
Default Re: Replacement Under Dash Light Bulb Sockets? (vettfixr)
Try AUTOZONE. I think I got one there to replace one of mine that was busted, Not NCRS but functionally correct. Also Junk yard, any GM product of that era.
Greg
Old Dec 2, 2003 | 10:11 PM
Wrencher's Avatar
Wrencher
Default Re: Replacement Under Dash Light Bulb Sockets? (76greg)
I just cut a half dozen out of a '66 Corvair ( along with a gold mine of other stuff - I was there 2 hours!) in the local wrecking yard. Exact same, but better for some reason. I can pull half the ones on the Corvette apart, but the 'vair sockets are tight? go figure...
Hans
Old Dec 3, 2003 | 02:35 PM
The Money Pit's Avatar
The Money Pit
When I redid my speedo to the 140mph unit I replaced all the dash lights while it was apart.Went to a local autoparts store and wanted to buy replacement bulbs,but the new bulbs were attached to a new socket.The whole shabang replaces the twist in socket.
I understand there are LED replacements also,though I think they're rather expensive.
To Replacement Under Dash Light Bulb Sockets?
