Ride Height
Old Dec 2, 2003 | 11:53 AM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Ride Height
I'm working on a new project here and I need to ask a favor from you guys. Could you please give me your ride height measurement in the FRONT only. From the ground to the center of your wheel well lip. I don't care if you have a front monospring, cut springs or whatever. Just please tell me if you have a SB or BB and the ride height. Thanks to everyone.
Dan :thumbs:
Old Dec 2, 2003 | 12:01 PM
Cor6996vette's Avatar
Cor6996vette
Default Re: Ride Height (Van Steel)
It 's 26 1/4 . 400sb w/allum . heads,removed AC.allum. rad. http://pic1.picturetrail.com/VOL133/...7/39030142.jpg http://pic1.picturetrail.com/VOL133/...7/39030066.jpg
Old Dec 2, 2003 | 12:05 PM
79VetteMike's Avatar
79VetteMike
Hi Dan-I have the monospring from you guys and the tubular upper and lower control arms. I don't have the engine back into the car yet though. The nuts on the lowering bolts at the end of the spring are only threaded on about 1-1.25 inch. The ride stiffness blocks are on the second softest setting. It's still real stiff. I plan on tightening the bolts up another inch to compensate for the engine and trans weight. I only have about 3 inches of shaft showing on the Bilsteins. How much should I have? It seems like they are bottoming out. By the way, the entire engine bay is gutted. The core support is out, the engine and trans are out, the heater box is out and all of the hood latches, windshield wiper motor, cruise control, and everything else is out of the engine bay, except the headlights. Anyway, my ride height is about 28 5/16". I hope that helps. Oh yeah- do I need the sway bars with the fiberglass springs? Thanks....Mike
Edit: my tires in the front are 255/60/15's
[Modified by 79VetteMike, 11:06 AM 12/2/2003]
Old Dec 2, 2003 | 12:18 PM
FeedVaal's Avatar
FeedVaal
Default Re: Ride Height (79VetteMike)
27 3/4 small block 255-60-15
Old Dec 2, 2003 | 12:44 PM
Glensgages's Avatar
Glensgages
With just 21,550 miles, I doubt my '82 has 'settled' much, so, here goes:
Wheel-well lip, directly above spindle: 28 & 1/16"
fender peak, directly above spindle: 33 & 3/4"
Front-Bottom corner of rocker-moulding: 8 & 1/2"
* I replaced the OEM 255/60R15 Eagle GTs with BFG Radial TAs of the same 'size':
however, I think the BFGs are a bit 'taller'*
Old Dec 2, 2003 | 01:46 PM
The Dude's Avatar
The Dude
Small block car. 27.5" both sides.
Old Dec 2, 2003 | 01:55 PM
Corey_68's Avatar
Corey_68
Default Re: Ride Height (The Dude)
27 1/4 Big Block w/ #550 springs
:cheers:
Old Dec 2, 2003 | 03:16 PM
PatsLs1vette's Avatar
PatsLs1vette
Default Re: Ride Height (Corey 68)
27 1/2- #450 springs cut down.
Old Dec 2, 2003 | 04:58 PM
Van Steel's Avatar
Van Steel
Default Re: Ride Height (patsnitrovette)
Thanks a million guys. All the info is appreciated. Keep it comin.
Mike
I'm still running a front sway bar on my 80 w/that same front monospring. I have 2 vettes here that I measured the shocks on. One is a mid year (same frame) and it measures 2 5/8". He's running KYB's. I also have an 80 here, which is a forum members car, and I just pulled the engine out. His ride height is 30 1/2" and his shock shaft shows about 3 1/2 - 3 3/4" roughly. So I don't think yours is far off.
Old Dec 2, 2003 | 07:21 PM
MN-Brent's Avatar
MN-Brent
28 1/4 inch with Dunlop 255/60R15s and 2 1/4 inch gap. Stock FE7 suspension. I think the cold tires look a little low on air though as my tire is at 26 inch height and should probably be a little closer to 27 inch. I keep them inflated right at 34PSI and thats where they were when I put it up around Halloween.
I believe this next summer I might be cutting 3/4 coil with a front poly rebuild.
Anyone know the spring rate of the 82 FE7 spring?
Im starting to think that in 82 the only difference between STD and FE7 suspension was change from composite to steel spring, a rear sway bar addition and possibly different shocks.
Brent...
Old Dec 2, 2003 | 07:32 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Ride height - 27 1/4"
Engine - 454CI
Tires - P225/70R15
[Modified by 71-LS5, 6:33 PM 12/2/2003]
Old Dec 2, 2003 | 07:36 PM
stpman's Avatar
stpman
Default Re: Ride Height (MN-Brent)
'73 327 SB
28 3/4" both sides 235/60/15 GT Qualifiers
'74 350 SB
28 1/2" Drivers side
28 3/4" Passenger side 225/70/15
Steve :steering:
[Modified by stpman, 7:37 PM 12/2/2003]
Old Dec 2, 2003 | 07:59 PM
BSeery's Avatar
BSeery
From: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
26 inches with 25.9 inch tires.
Small block, with A/C, aluminum heads, intake, water pump and headers instead of manifolds. 460 springs cut 1 1/3 - 1 1/2 coil (I know you didn't ask, but I offered).
It's too low some times, like for speed bumps with headers. Other than that it looks :cool:
[Modified by BSeery, 5:01 PM 12/2/2003]
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
26.5..... 460's cut down.
Old Dec 2, 2003 | 08:11 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Mine is 27 3/4 with 255/60R15 front tires and 460 lbs/inch front springs
[Modified by GrandSportC3, 8:12 PM 12/2/2003]
Old Dec 2, 2003 | 08:55 PM
PigPen's Avatar
PigPen
26.25", sb w/ac, VBP's 550's uncut.
Old Dec 2, 2003 | 09:38 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Ride Height (PigPen)
Smallblock with VB Grand Touring Springs 460LB
Drivers Side 28 inches
Passengers Side 28 1/2 inches
To Ride Height
Old Dec 2, 2003 | 09:41 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default Re: Ride Height (Eddie 70)
I think mine was somewhere around 27.5
small block, a/c removed.
its been so long since I had an engine in it.
Old Dec 2, 2003 | 09:53 PM
Steve Grodin's Avatar
Steve Grodin
Default Re: Ride Height (Corz)
26.75" SB.
Old Dec 2, 2003 | 10:03 PM
jbroughton's Avatar
jbroughton
'69 350, aluminum heads, no air, stock suspension, 235/60
DS = 27"
PS = 27.5"
