ZZ383.... it's available!!
Old Dec 2, 2003 | 08:33 PM
Scooter70's Avatar
Scooter70
Default ZZ383.... it's available!!
ZZ383/425 425 HP 383 Small Block Crate Engine with Aluminum Heads
Price: $4,699.75
Part # 12498772
Doesn't include intake, ingition, flywheel, but does have FastBurn heads, roller cam (509/528, 222/230 duration at .050 lift)
http://www.sdpc2000.com/cart.asp?act...120&pid=156334
Soooooo tempting... but the Fastburn heads won't work with Hooker sidepipes, right?
Old Dec 2, 2003 | 08:40 PM
SharkAttack's Avatar
SharkAttack
Default Re: ZZ383.... it's available!! (Scooter70)
I can't comment on the header fit, but that is one sweet small block!
Old Dec 2, 2003 | 08:52 PM
Glensgages's Avatar
Glensgages
:confused:
is the exhaust port raised?
Old Dec 2, 2003 | 08:57 PM
QuickVet's Avatar
QuickVet
Default Re: ZZ383.... it's available!! (SharkAttack)
sure is sweet. and the price is perfect too. :cheers:
Old Dec 2, 2003 | 09:23 PM
DGT76's Avatar
DGT76
St. Jude Donor '03 & '05
:cool: Looks good!!
Old Dec 2, 2003 | 09:30 PM
LFZ's Avatar
LFZ
tempting....very tempting.....I just wish i had 5 grand laying around.
Old Dec 2, 2003 | 10:39 PM
Scooter70's Avatar
Scooter70
Default Re: ZZ383.... it's available!! (Glensgages)
I believe so. I'm researching now to find out. If anyone knows for sure, let a brutha know.
Old Dec 2, 2003 | 10:48 PM
QuickVet's Avatar
QuickVet
if you can, see if they will work with Hooker Super Comps!
Old Dec 2, 2003 | 11:03 PM
Older Than Dirt's Avatar
Older Than Dirt
Default Re: ZZ383.... it's available!! (QuickVet)
I'm running Super Comps on my fast burns right now. Shortly I'm about to make a transmission change and I'm installing a set of hooker side pipes then. :thumbs:
Old Dec 2, 2003 | 11:16 PM
Stoge's Avatar
Stoge
What intake / carb combo could you use that would also fit under the hood?
Old Dec 3, 2003 | 06:08 AM
Scooter70's Avatar
Scooter70
Default Re: ZZ383.... it's available!! (Stoge)
Older Than Dirt: It's not the ports themselves that are the issue, it's the location of the ports relative to something that doesn't move. (ie the frame where the sidepipes mount.) SDPC told me that the Vortec and L98 (ZZ4) heads have the standard exhaust port locations, so that would mean that they would work with side exhaust. The tech didn't confirm that the Fastburn heads have raised ports, so I'm still searching.
Stoge: Depends on which hood you have. I have a long L-88 hood, so clearance isn't an issue. :cheers: I'm sure there are a ton of threads regarding which intakes can fit under a smallblock hood.
Old Dec 3, 2003 | 02:28 PM
Corvette_fetish's Avatar
Corvette_fetish
ZZ383 -or- ZZ454??????? Oh, the decisions!! (Dep, I already know your opinion!)
Old Dec 3, 2003 | 04:53 PM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: ZZ383.... it's available!! (Corvette_fetish)
They say in the blurb about the fast burn heads that if you install a .540 lift roller cam and a single plane you can get 500hp out of it......
Just a thought. But it looks like a good buy :thumbs:
GM’s testing was completed using a GM single plane intake, P/N 12496822 and a 750 CFM Demon carburetor with mechanical secondaries. Test header specs are: 13/4" primaries, 33 inches long with a 4-inch collectors. GM dual plane intake P/N 12366573 may be used for hood clearance on the ZZ383/425, but it results in a decrease in peak horsepower of approximately 15-20 horsepower.
This might be something to keep in mind as well.
[Modified by Guru_4_hire, 4:55 PM 12/3/2003]
Old Dec 3, 2003 | 09:07 PM
QuickVet's Avatar
QuickVet
Default Re: ZZ383.... it's available!! (Guru_4_hire)
that is true with most motors though
To ZZ383.... it's available!!
