Will ZR1 Rims fit for 1973 Vert?
Does anyone have firsthand experience with fitting real ZR1 5 spoke rims (not GS or Camaro offsets) to a 1973? I am not really worried about the tire sticking out as I have greenwood flares on my 73. I am more interested in how the 275/40/17 and 315/35/17 fill out the wheel wells. I know I will need adapters, but not sure of the measurement yet.
Pics would be greatly appreciated. Thanks,
Location: Exiled to Richmond, VA - Finally sold my house in Murfreesboro, TN ?? Corner of "Bumf*&k and 'You've got a purdy mouth'."
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Will ZR1 Rims fit for 1973 Vert? (C56spd)
In the back of my 1980, with no flares, I have 285/40/17's on 17x9.5 wheels from a 1996 Vette. The tire hangs out about 1/4 - 1/2 inch and just misses the brake cable. If you move the e-brake cable, and go with a smaller size adapter they should fit inside the wheel well.
I don't know about any sizes larger than that though.
Re: Will ZR1 Rims fit for 1973 Vert? (BSeery)
.....If you move the e-brake cable, ....
Will the 275s fit without moving/removing the e-brake?
Do you have pictures from other angles? I am sure you do, please post
:cheers:
[Modified by desi, 12:28 PM 12/3/2003]
Re: Will ZR1 Rims fit for 1973 Vert? (desi)
I run 17x9.5 GS wheels with 56mm offset. I also have to use 3 inch adapters from VBP. I run 275-40-17's on all four corners without flares. The rear tires are about flush with the fender. I did not cut or move the E-brake. Hope this helps. :thumbs:
Re: Will ZR1 Rims fit for 1973 Vert? (BLKDOUT)
I believe my ZR1 rims are ~36.5 mm offset. I guess the only way to know is to fittest and measure. If they work, I will post some pics.
BLKDOUT, do you have any pics of your setup? I would love to see it.
Thank,
Thank,
