Powder coat vs. paint Q.
1. is it worth it?
2. does it look better than regular paint?
3. will it work on headers?
4. does someone have pictures of parts done under-hood area?
I know a lot of these topics have probably been covered but I couldn't find them.
Thanks for any help :cheers:
YES
YES, much toucher, resistant to oil, gas and other chemicals. Does not fade, hard to knock off.
Only very expensive high temp stuff. Ceramic coating is sort of a powedercoating application. Go with that.
Here's a lot of pwoerdercoat pics, all parts done by me :)
A VERY high performance manifold :lol:
(aircleaner is dented :( )
.. that should do for now ;) :D Have way more pics. I powdercoated about everything I could get mu hands on. All parts on my car are either zinc plated, new, powdercoated or urethane (the 2 component kind you have to cure in an oven) painted.
[Modified by Twin_Turbo, 6:47 PM 12/3/2003]
-Chris
The primer adheres to the metal or old paint surface, and the paint adheres to the primer. The “in-between” approach is marginal at best.
The better the preparation and quality of paint, the better it will look, and more importantly, the longer it will last. NOTHING lasts forever!
As for prepping parts, thoroughly clean with degreasers (I use lacquer thinner and Paint Prep) and bake at 400 for 20 minutes or so. Then let cool and coat, then bake again.
I do small parts in a toaster oven, larger parts in an oven I got at a garage sale for $50, and I have a 6000w heater for bigass parts.
Hey TT- they make powders in color now. ;)
(hood latches done in "stamped steel" and "reflective chrome")
I'm fabricating some parts for the radiator and cowl area, needed to do that after removing my old air filter system .
I'll try and post some pics when they are done.
I'll check Eastwood's for some materials.
:cheers:
Hey Mark, black is a color :D I have lots of colors but mainly stuck to black because I like black and I don't want the stuff to look like a fricken christmas tree :) I really like your color. I have some aluminum, stainless and titanium colors.
Hard to see but the latching mechanism is black again but the wiper turrets/stands are stainless.
