I have just received a *wonderful* present from my Corvette...a backfire problem.
I've dealt with carb backfires before due to my stabbing the distributor wrong, but this is driving me nuts.
My car, with no changes for the past several weeks has developed an exhaust backfire. It's on the passenger side bank and only one cylinder. I'm going out to double check the timing now, but I'm worried about it.
How likely is it that I've wiped a cam lobe? What are the other possible causes?
When does it backfire? If it does it when you let up on the gas, ie, the engine is braking the car, I would suspect an exhaust leak. Check the entire exhaust system from manifold to muffler, leaky gasket or a hole or break anywhere can cause a backfire. MJ
Mine has started backfiring through the exhaust too. It usually does it only when the engine is cold (under 160 degrees) and when increasing throttle. I guess its a carb problem?
My experience with engine backfire is that the cylinder is firing while
the exhaust valve is still open, rather than being shut as it should. I've seen
a slipped or loose timing chain as a possible problem. CDC
From: Las Vegas - Just stop perpetuating myths please.
Re: Engine started backfiring... (rainman69)
:rolleyes: I developed a misfire once from damaging the plug wire boots. I used a sharp toothed Leslie tool to remove the boots for a plug change. Started miss-firing and got worse. The spark was getting to ground on the exhaust manifolds through pin holes in boots.
Also have read where headers will destroy plug wires in short time with heat.
I have had a wiped lobe on #4 exhaust that produced just a low RPM/idle miss and does not sounds like your problem. You could remove valve covers and measure valve lift (with the lifters still pumped up – maybe engine running). But this is not an easy job. :seeya
Sounds like unburnt fuel is collecting in the exhaust from an intermittent miss and being ignited on the subsequent cycle. Usually an ignition problem but sometimes a valve problem can cause the same thing. Look for a fouled plug, bad wire or connection, distributor cap, etc..
The only other time I had a backfire one of my sparkplug wires had fallen off the plug. Easy fix for me, but a bad wire could cause the same problem. MJ
