Hartop mounting
Old Dec 9, 2003 | 09:35 PM
71LS5's Avatar
71LS5
St. Jude Contributor
Default Hartop mounting
Question:
1. How does one put a wingnut etc on the hardtop rear threaded pin to keep the rear down? I can not get my hand in there with the soft top folded up.
2. What is used for this (ie wingnut washers etc)
Thanks,
Shark71ls5
Old Dec 9, 2003 | 09:43 PM
dreamn2's Avatar
dreamn2
Default Re: Hartop mounting (71LS5)
If your talking about the corner pins, mine has the self locking nuts with the nylon threads set at a predtermined depth. They self latch just like the soft top when put on. I don't know if thats the way they came or Bubba's been here but it works. :D
Old Dec 9, 2003 | 09:45 PM
Crash Dummy's Avatar
Crash Dummy
I can't help you, but it appears that the new nick I chose is was pretty much taken. Guess it's time for a new one. By the way.... hello from another '71 LS5 owner. All original here.
Old Dec 9, 2003 | 10:02 PM
71LS5's Avatar
71LS5
Default Re: Hartop mounting (dreamn2)
Not the corner pins the cnter threaded bolt that requires a nut.
Old Dec 9, 2003 | 10:04 PM
71LS5's Avatar
71LS5
Hey 71-LS5 nice car :cool:
Old Dec 9, 2003 | 10:05 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Okay the question is do I have to have the lock nuts on or is it safe to drive with just the front and rear hold downs.
dreamn2's Avatar
dreamn2
Not sure. I dont use mine.
Old Dec 9, 2003 | 10:09 PM
71LS5's Avatar
71LS5
I assume you need to use the bolt to sinch down the hard top. When I go over bumps the hard top flops. Maybe the two mounting pins are just not adjusted so well.
In any event we have a theraded pin for this purpose and it aint easy to get at it (as with many parts on this thing).
Old Dec 11, 2003 | 01:21 AM
WESCH's Avatar
WESCH
Hi
No, that's been Bubbaed, but the best idea, that can be done.
The top will not fly off when it's bolted to the side posta, attached to the front window latches and to the back with the soft top type pins.
The center hole ( 69 and later ) is only a locating pin.
Good luck. Gunther :seeya
Old Dec 12, 2003 | 10:50 AM
Milest's Avatar
Milest
Default Re: Hartop mounting (WESCH)
With the corner pins and side bolts secure, I just pop open the lid and have a friend hold up the top (it is very heavy) and fit the wingnut.
Old Dec 12, 2003 | 12:55 PM
mayberg's Avatar
mayberg
Anybody got a pick of what this center bolt/wing nut thingy is supposed to look like? Mine's long gone.
Old Dec 12, 2003 | 01:25 PM
69Sting's Avatar
69Sting
Default Re: Hartop mounting (mayberg)
The couple times I use my hard top I just took the side pins from the soft top and used those on the hard top. I don't have the center hole (luckely) but I did read in a mechenics book that the middle hole is only for alignment and worth less. Many people will just fiberglass it in.
I must say I like the idea of poping the top and tighting down the hard. There is a lot of rattling when you use the soft top pins. :cheers: :smash:
Also make sure you put another coat of wax on the deck. Or get the clear protector tape from Mid America. You will get a soft top and hard top line. I have both lines and they don't buff out.
Old Dec 13, 2003 | 01:24 AM
71LS5's Avatar
71LS5
Default Re: Hartop mounting (69Sting)
Hey MILEST best sugestion yet! I am convinced that the hardtop must be installed with the soft top removed. Like we all have time for that....
I will try it...
THANKS!!!! :steering:
Old Dec 13, 2003 | 01:27 AM
71LS5's Avatar
71LS5
Oh and by the way...I think the assembly manual might show you guys what the correct hardware looks like. I think its a 1/4 stud attached to the top and then a plastic wingnut and two special washers (bevel top crome flat plastic botom to form a seel) :smash:
To Hartop mounting
