Side Exhaust conversion
Old Dec 10, 2003 | 07:31 PM
Brutus2122's Avatar
Brutus2122
Default Side Exhaust conversion
How hard is it to convert from standard rear exhaust to side exhaust? And about how costly is it? Thanks
Old Dec 10, 2003 | 07:55 PM
lbell101's Avatar
lbell101
Default Re: Side Exhaust conversion (Brutus2122)
A grand and it's easier than replacing the old duals. Assuming original 69 style with repro covers.
Larry
Old Dec 10, 2003 | 08:08 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Sidepipes are cool, but there are some things to think about.
1)They can be loud. Many of us want that.
2)You will have inserts in the back where the old exhaust came out that will not look right. The mufflers & tips filled area. You might want to change out the rear inserts with *blanks* where the exhaust used to exit to fill in the void. Of course you will have to prep & paint them to your color.
Other than that, I had a set of chrome hookers on a '69 and loved the sound with a 4 speed. They tended to rust though.
Old Dec 10, 2003 | 08:53 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
As you probably know, your 69 is the only C3 that could come from the factory with side exhaust. I just had to have these for my 70 back in 73. Very easy to install after removal of the underbody car exhaust. One of the things I liked about the factory style side exhaust was how easy it was to remove and replace. Connects at the exhaust manifold and the rear of the side exhaust pipe, real easy installation of the side exhaust muffler. If you are going to do this, the original style three piece chrome coverings and the insulation covering could be more expensive than what you want to spend. When I removed my 69 style side exhaust about 15-16 years ago, the mufflers were nothing but expansion chambers for the exhaust and were loud. My neighbor knew when the car was started and came home. Got a lot of enjoyment out of them, going about 30 and letting the automatic shift down into first will pedal to the metal made some noise.
[Modified by 70ZZ3 96LT4, 1:55 AM 12/11/2003]
Old Dec 10, 2003 | 10:45 PM
72ls5fla's Avatar
72ls5fla
I would say that if you do the factory side covers and pipes, the cost will be about 2,500.00 for exhaust parts. Another 200.00 plus finishing labor to change the rear valence and have the new one repainted ...
They sound really nice, but in my opinion are way to loud ...
I have to wear ear plugs on road trips just so I don't get deaf.
I am switching the ar to original exhaust this spring ...
Looking foward to cruzing and playing my radio.
My opinion for what it is worth ...
Bill
Old Dec 10, 2003 | 11:01 PM
Red73's Avatar
Red73
Default Re: Side Exhaust conversion (72ls5fla)
If you're going with Hooker Side pipes you may need to trim the side molding like the first photo and if you want to fill in the exhaust holes in the rear you can buy the rear panel from most corvette vendors like the second photo.
To Side Exhaust conversion
