Kiesler install...CAUTION...large pix ahead...
Old Dec 10, 2003 | 10:48 PM
OkeeGuy's Avatar
OkeeGuy
Default Kiesler install...CAUTION...large pix ahead...
well folks...about 3 hours comin out...
about 3-1/2 hours goin in...so far...
all ive got to do is put the driveshaft back in and put the interior back together...
here is a summery of how it went...
we screwed up and put the yoke on the driveshaft and then tried to install it...
UH UH...dont work that way...
gotta bolt the driveshaft to the rear and THEN put the yoke on...
under the car... :rolleyes:
the speedo cable was another unexpected treat...what a PITA to get that was to get out of the backof the speedo...
my back is still feeling the pain from that one! :)
when under the dash like that, ya kinda wish you had another arm coming out of your head!
also...as you can see from one of the pix...i cut my exhaust...
it is nearly impossible to get this larger trany up in there...
my sidepipes wil be here in a day or two so its really no biggy...
its rainin here and will be for a couple more days anyway... :rolleyes:
the only other thing that sucked was having to put the trany AND the bell housing up in there at the same time...NOT bolted together...
it a good thing my buddies were there to help me because it took some wrasslin and jugglin to get it in there!
two under the car and one on the jack...
im gonna button it up and ill let yall know how it all works out...
thanx everyone for your help along the way!
[Modified by SIGNGUY, 10:53 PM 12/10/2003]
Old Dec 10, 2003 | 10:52 PM
427V8's Avatar
427V8
C6 the C5 of tomorrow
Default Re: Kiesler install...CAUTION...large pix ahead... (SIGNGUY)
Well it L :cool: :cool: KS good!
Old Dec 10, 2003 | 10:57 PM
74 vert's Avatar
74 vert
From: Where are the Smoky Mountain Cruisers? Not Correctly Restored Stingray
Default Re: Kiesler install...CAUTION...large pix ahead... (427V8)
:thumbs: and looks good too.
Old Dec 10, 2003 | 11:05 PM
blunsford's Avatar
blunsford
Man that is a clean underbody. Anytime you wanna come show me how to get it that clean is good for me! :blueangel:
Old Dec 10, 2003 | 11:06 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
It'll be worth the effort once you are done!! :smash: :smash:
Old Dec 10, 2003 | 11:07 PM
DGT76's Avatar
DGT76
St. Jude Donor '03 & '05
Default Re: Kiesler install...CAUTION...large pix ahead... (blunsford)
:cool: :cheers: :cheers: :thumbs:
Old Dec 10, 2003 | 11:17 PM
1971Ultra's Avatar
1971Ultra
Default Re: Kiesler install...CAUTION...large pix ahead... (DGT76)
So far, soooo good. :thumbs:
Old Dec 10, 2003 | 11:23 PM
OkeeGuy's Avatar
OkeeGuy
actually...it has always been garage kept and i never drive it in the rain...
unless i get caught!
thanx for the compliments guys! :)
im pretty happy so far... :yesnod:
Old Dec 11, 2003 | 06:30 AM
Yeller81USNRet's Avatar
Yeller81USNRet
Looking GOOD Guy...
:cool:
:steering:
Old Dec 11, 2003 | 08:01 AM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Default Re: Kiesler install...CAUTION...large pix ahead... (Yeller81USNRet)
http://www.photohost.org/gallery/data/500/399DSC01416-1.JPG
Gary, you better have your yoke ready if you have already filled the tranny with fluid because you are gonna lose some when you pull this plug out. I threw a t-shirt away after I pulled this plug.
Also you are at the harder parts of the install. I bought a 5 inch c-clamp to put the yoke and the driveshaft together. Put the fixed end of the clamp on the body of the yoke and the moveable end on the cap you are trying to press. Worked out nicely for me if you have someone to help hold the driveshaft in place while this is going on. Good luck. You only have about 30 minutes work left. :thumbs:
Old Dec 11, 2003 | 12:35 PM
markdtn's Avatar
markdtn
Default Re: Kiesler install...CAUTION...large pix ahead... (Eddie 70)
Nice! :thumbs: :thumbs:
Old Dec 11, 2003 | 12:42 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Re: Kiesler install...CAUTION...large pix ahead... (markdtn)
:cool: my old 77 was clean like that. I have a longgggggggggggggg road ahead with the 68. Feel free to come over with a wire brush and help.
:jester
Old Dec 11, 2003 | 12:45 PM
SmokedTires's Avatar
SmokedTires
Cruise-In III Veteran
St. Jude Donor '05
Boy I wish that kit was around when I did my install 2 years ago, it sounds like it's much easier than what I went through :crazy:
You'll love the O/D !!! Nice job. :cheers:
Old Dec 11, 2003 | 01:47 PM
jac1502's Avatar
jac1502
Default Re: Kiesler install...CAUTION...large pix ahead... (SmokedTires)
Is that a stock cross member? Im looking for one similar for my 81
Old Dec 11, 2003 | 05:54 PM
OkeeGuy's Avatar
OkeeGuy
Default Re: Kiesler install...CAUTION...large pix ahead... (jac1502)
yup...stock "welded in" crossmember...
as far as the yoke goes...well that was another story...
79...the "bastard" year...
if you are odering for a 79 be sure to tell them if you have an early or late 79 cause the early (mine) had a large yoke at the rear end and the late 79 had the small...
they gave me the wrong one so off to the parts store i went...
got a 1310/1330 u joint...it came with a 1330/1330...
the 1330/1330 has equal lenght diameters and the 1310/1330 has them long one way (to fit my yoke) and shorter the other way to fit the drive shaft...
went in pretty slick...
installing the front ujoint wasnt nearly as hard as i thought it would be...
the only test drive i got was 3 miles from work to home as i am running off straight headers...hense i couldnt really appreciate the trany...yet.
in the morning im going straight to the exhaust shop to get hooked back up...
then its off for a real test drive!
ill let yall know!
To Kiesler install...CAUTION...large pix ahead...
