Grinding noise from clutch
Old Dec 11, 2003 | 12:39 PM
Cali,68,L-79's Avatar
Cali,68,L-79
Default Grinding noise from clutch
When car is cold and I depress or hold the clutch between 3" to fully against the carpet while putting int ogrear i hear this horrible SCREEEEECH!!!!! noise. If I slam the clutch pedal to the floor it goes away. It only occurs when engine is cold. At 4-5" to bottom of pedal travel the cluch is completely disengaged so I do not know why the hell this is happening.
:confused:
Old Dec 11, 2003 | 02:51 PM
rollavette71's Avatar
rollavette71
Default Re: Grinding noise from clutch (Cali,68,L-79)
Sounds like the classic throw-out bearing-gone-bad symptom. Tranny will need to come out.
Old Dec 11, 2003 | 03:07 PM
MikeC's Avatar
MikeC
Default Re: Grinding noise from clutch (rollavette71)
Yup thats what is sounds like.
Might as well replace the clutch when you do this as you have probably damaged the pressure plate.
Gotta love a $20 dollar part that causes a couple hundred in damagewhenit goes bad.
Buy a high quality throwout beaaring. I bought the centerforce once when I orginally put in My centerforce clutch it cost extra but it was still working on its second clutch when the engine went bad.
Old Dec 11, 2003 | 03:45 PM
Cali,68,L-79
Default Re: Grinding noise from clutch (MikeC)
Oh shiznit why me!! I just bought the house and $400 plus dollars is not on my avaiable budget with mrs .cali buying;
1. carpet- 4-6k
2. all new appliances- 2.5K
3. repaint house- nope I'll slave over that
4. etc. etc
Okay give me the lowdown what's needed and estimated costs.
:cuss
Old Dec 11, 2003 | 03:55 PM
lbell101's Avatar
lbell101
You don't really need to change anything but the bearing if you don't have the cash. If you do it yourself all it will cost is the cost of the bearing and an afternoon. And alot of swearing.
Larry
Old Dec 11, 2003 | 03:57 PM
rollavette71
1. Drop Tranny
2. Pull flywheel - have resurfaced - approx. $50
3. Replace disc, pressure plate, throw-out bearing, pilot bearing/bushing
Cost depends on vendor - maybe $200-$300?
4. Put it all back together. Be sure to use the alignent tool when bolting up the disc and pressure plate. And use good fasteners on the flywheel and pressure plate. Chase all threads before torquing up.
Good luck!
Hank :cheers:
Old Dec 11, 2003 | 04:38 PM
DJ Dep's Avatar
DJ Dep
St. Jude Donor '05-'07
1. Drop Tranny
Good luck!
Hank :cheers:
HA! Hank is living on Fantasy Island over the winter or his money tree is still in full bloom!!! :lolg: :lolg:
Here's something that MIGHT work, depending on your car.
#1Remove driveshaft.
#2Support trans on a floor jack with good wheels on it.
#3 Unbolt trans and slide it back and down far enough to get the input shaft out of the throwout bearing and the trans out of your way.
#4 Reach inside the hole where the trans is and feel around for the throwout bearing. It will be attached to the clutch fork with two cheesey clips.
#5 Slip the throwout bearing OFF the clutch fork and pull it out the hole where the trans goes.
#6 Take the new throwout bearing (I think they cost around $20) and clip it on the clutch fork.
#7 Slide the trans back in making sure the input shaft goes THROUGH the throwout bearing. (That's the trickiest part).
#8 Bolt up the trans and driveshaft and away you go.
If you have trouble getting the trans back in just twist the input shaft a little so the gear teeth line up.
Most GM stick shifts have an inspection plate on the bellhousing. That may help you with lining the input shaft of the trans with the throwout bearing. But it's not really difficult to find the hole. I could make a nasty remark about how to make the hole easier to find, but I better not ;)
Dep
[Modified by Dep, 3:41 PM 12/11/2003]
Old Dec 11, 2003 | 04:49 PM
Cali,68,L-79
Default Re: Grinding noise from clutch (Dep)
Okay that sounds alot better than $500.
:cry :cry :cry :cry
Old Dec 11, 2003 | 05:44 PM
FeedVaal's Avatar
FeedVaal
1. Drop Tranny
Good luck!
Hank :cheers:
Dep
:iagree:
Dep left out step 1.5 : Support back of engine with piece of wood or cutoff broomstick before removing trans to prevent contact of distributer with firewall or fan with shroud.
:cheers:
Old Dec 11, 2003 | 06:06 PM
MikeC's Avatar
MikeC
Default Re: Grinding noise from clutch (FeedVaal)
If budget does not allow a new clutch you can get by with only replacing the throwout bearing.... but its while-you-are-at-it-itus. Its easier to replace the clutch now while it is out.
Do not drive it until it is fixed, as you are damaging the pressure plate everytime it grinds.
I payed $450CA for a centerforceII so if you want to get by with a clutch replacement, just get a budget replacement unit from your local autoparts store should only run $200 or so including cleaning of the flywheel.
Old Dec 11, 2003 | 10:32 PM
trw's Avatar
trw
Screech noise does not mean the bearing has wreaked the pressure plate.
I agree replace bearing, cheap even a $35, no other parts to buy only labor.
If it goes bad again, maybe it will be at a better financial time.
Good luck.
Terry
Old Dec 11, 2003 | 11:03 PM
Crash Dummy's Avatar
Crash Dummy
St. Jude Contributor
Ouch David. Gremlins.
Old Dec 11, 2003 | 11:08 PM
MikeC's Avatar
MikeC
Default Re: Grinding noise from clutch (trw)
TRW, Where did I say the screech noise wrecked the pressure plate?
IF you Throwout bearing is shot... it probably means the bearing is seizing to some extent( I get that from the screech noise, as a loose bearing does not go screech). That seize will damage the fingers of the pressure plate. I have experienced this first hand. The bearing will take the brunt og the damage but the fingers will incurr damage also.
Old Dec 11, 2003 | 11:15 PM
DJ Dep's Avatar
DJ Dep
Okay okay...let's not get all snippy with each other. We agree the bearing needs to be replaced soonish. Doesn't matter if it's a screech or whine or hiss...it's noise that SHOULDN'T be happening. And yes...I forgot to mention supporting the engine. Now if everyone is done splitting hairs and whining, let's let David get his car fixed :)
Dep
Old Dec 11, 2003 | 11:48 PM
Cali,68,L-79
Dep
:lurk:
Okay with that said whose coming over to help me?
:jester
Old Dec 12, 2003 | 12:00 AM
DJ Dep's Avatar
DJ Dep
Dave: Here's the deal....
You pay my plane fare round trip....coach is fine. You put me up in an inexpensive motel room. You pay for all my pizza and Diet Pepsi.
And I can be on a plane tomorrow! :)
Dep
Old Dec 12, 2003 | 12:04 AM
Cali,68,L-79
What kind of pizza you like?
:D
To Grinding noise from clutch
Old Dec 12, 2003 | 12:14 AM
DJ Dep's Avatar
DJ Dep
Crust must be very thin...like Holy Communion.
Sausage and maybe pepperoni. Even though I was born and raised in the Chicago area, I never got into that thick "Chicago style" pizza.
Dep
Old Dec 12, 2003 | 12:25 AM
Crash Dummy
Sparky...
Put Puddles on a SAIA truck and housing at the YMCA. Cheaper! And frisk his butt for wrenches before he leaves.
Old Dec 12, 2003 | 12:39 AM
DJ Dep's Avatar
DJ Dep
Default Re: Grinding noise from clutch (Winging It)
Hot Wings: I heard we got some newbies in. You're slipping up on your duties ;)
Dep
