Differential Plug Question
Old Dec 12, 2003 | 10:39 AM
Robert8096's Avatar
Robert8096
Default Differential Plug Question
I removed the plug to check the fluid level. Is the plug supposed to go back flush with the differential cover or is there some extra threads on the plug? It seems that when mine is completely tight there is some extra threads exposed. Is this normal? It is a 1980 model and does not seem to be leaking.
Old Dec 12, 2003 | 11:35 AM
mapman's Avatar
mapman
Default Re: Differential Plug Question (Robert8096)
The plug uses tapered threads so it is normal to have some threads showing. With the aluminum Dana rear ends you don't want to tighten it too much and strip out the threads. (I also have an 80 that I am in the process of rebuilding.)
Old Dec 12, 2003 | 12:19 PM
Robert8096's Avatar
Robert8096
Thanks for the info.
Old Dec 12, 2003 | 12:20 PM
Van Steel's Avatar
Van Steel
Premium Supporting Vendor
Default Re: Differential Plug Question (mapman)
:iagree:
To Differential Plug Question
