Need help with timing light
Old Dec 15, 2003 | 11:58 AM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Default Need help with timing light
My timing light and dwell meter have to be hooked to the positive and negative battery terminals. Since the battery is behind the drivers seat, is there an alternative place within the engine compartment?
Old Dec 15, 2003 | 12:04 PM
7vette2's Avatar
7vette2
Default Re: Need help with timing light (6t9l4t6)
Use the positive terminal on the alternator and gound to the engine. (bracket etc.)
mayberg's Avatar
mayberg
I use the hot lead out of the back of the alternator.
Old Dec 15, 2003 | 12:47 PM
vvv90's Avatar
vvv90
Default Re: Need help with timing light (mayberg)
Will that still work even if you're just trying to time it while the car is being cranked over?
Old Dec 15, 2003 | 01:15 PM
7vette2's Avatar
7vette2
Default Re: Need help with timing light (vvv90)
Yes, the positive terminal on the alternator is always hot as long as the battery is connected.
Old Dec 15, 2003 | 01:45 PM
jrzvette's Avatar
jrzvette
Default Re: Need help with timing light (7vette2)
THANKS
Old Dec 15, 2003 | 03:15 PM
Sigforty's Avatar
Sigforty
Cruise-In IX Veteran
I normally use the power line to the ballest resistor or the coil for power.
Old Dec 15, 2003 | 03:57 PM
comp's Avatar
comp
Default Re: Need help with timing light (Sigforty)
or spare batt. it doesn't care where power sorce come's from
Old Dec 15, 2003 | 04:04 PM
Kevin_73's Avatar
Kevin_73
Cruise-In X Veteran
St. Jude Donor '09-'11
+ to either the positive lead on the back of the alternator, or the horn relay (just under the drivers side fender on my 73)
- to any bare metal that is clear of belts and moving parts.
To Need help with timing light
